Hi.
I have soft type of WTPart and soft type of WTPartUsageLink.
How can i specify my link soft type while adding one part to structure?
I cann't create relationship constraint for my link soft type, only for WTPartUsageLink. Where and what do i need set in settings to enable this option?
Thanks.
I set wt.part.allowMultipleUsageLinkTypes to true with the following command:
xconfmanager -s wt.part.allowMultipleUsageLinkTypes=true -t codebase/wt.properties -p
Now i able to set parent and child constraints for my UsageLink soft type.
But "Insert Existing" action in Structure is broken now. I cann't add any exisiting part because searching is not working.
Resolved.
Previously i have added child part soft type to wt.typepickerexclude/wt.part.WTPart property.
I removed it and "Insert Existing" is working fine now. Action creates usage link soft type i need.
