Relationship between Plant Functional Data (Plant1) to Plant Functional Data (Plant2)
BEA_SP
3-Newcomer
Hello All,
I need to construct a direct relationship between plant functional data for plant1 to plant functional data for plant2, these plant functional data belong to the same part but are for different plants.
what is the link type I can build for this use case
Hi @BEA_SP,
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
Andra
