We have manual numbering in effect.
Currently dealing with a zillion mis-matches between CAD Doc Number and Filename, primarily from users Renaming in Workspace and trying to prevent mismatches in the future..
Found this article and would like to implement: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS130857&art_lang=en&posno=2&q=name%20match%20number&ProductFam…
note: The article lists making "Name" same as filename and Number. We'd like to exclude Name and allow it to remain as descriptive words.
Anyone care to volunteer more info on how to "implement a listener" in general?
thx
PFA listern for Renaming. compile attached java classes and register listener with in wt.properties with below command
Xconfmanager –s wt.services.service.660002=ext.sra.listener.ListenService/ext.sra.listener.StandardRenameListenService –t codebase\wt.peroperties –p
you can modify criteria as per your requirement.
Let me know if you need more details
Hope it helps!!
Shreyas
