hi,
what you get is a wt.change2.WTChangeIssueMasterIdentity (which is a
wt.change2.ChangeIdentificationObject which in turn is a
wt.fc.IdentificationObject), so you need a cast:
wt.change2.WTChangeIssueMasterIdentity id =
(wt.change2.WTChangeIssueMasterIdentity) ci.getIdentificationObject();
hth, martin
David Graham wrote:
> Anyone know how to rename a persisted object such as a
> wt.change2.WTChangeIssue?
> PTC said to try the following
> wt.fc.IdentificationObject id = ci.getIdentificationObject();
> id.setName(name);
> wt.fc.IdentityHelper.service.changeIdentity(ci, id);
> This sounds good on paper however there does not appear to be a setName()
> method in the wt.fc.IdentificationObject class.
> I want my class to read something like the following:
> import wt.change2.*;
> import wt.util.WTException;
> public class WfRenameCI {
> public void renameCI (WTChangeIssue ci, String name) throws WTException{
> if (!(ci.getName().equals(name))){
> //Rename the Change Issue
> id.setName(name);
> David
