Anyone ever have this error show up in tomcat on replica.
Info*Engine servlet: resource URI = D:/ptc/Windchill_9.0/Windchill/codebase/WEB-INF/ie.properties
java.io.FileNotFoundException: D:\ptc\Windchill_9.0\Windchill\codebase\WEB-INF\ie.properties (The device is not ready)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:106)
at java.io.FileInputStream.<init>(FileInputStream.java:66)
at com.infoengine.au.IEProperties.resetProperties(IEProperties.java:1129)
at com.infoengine.au.IEProperties.resetProperties(IEProperties.java:1081)
at com.infoengine.au.IEProperties.resetProperties(IEProperties.java:1059)
at com.infoengine.au.NamingService.setProperties(NamingService.java:1335)
at com.infoengine.au.NamingService.newInstance(NamingService.java:286)
at com.infoengine.au.NamingService.newInstance(NamingService.java:218)
at com.infoengine.IeServlet.init(IeServlet.java:169)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1173)
at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:993)
at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4149)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4458)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:526)
at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:630)
at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:556)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:491)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1206)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:314)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:722)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
at org.apache.catalina.core.StandardService.start(StandardService.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:583)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
Info*Engine servlet "com.rdtool.srvwindchill.servlet" initialization failed
Hi Joe,
It looks that you ie.properties is missing or is corrupted, name has changed etc.
Can you check if it is still there?
The ie. properties file is still there. But on my replica, PDM LInk is installed on E: not 😧 as referenced by the error.
