Version: Windchill 12.1
Use Case: configure a replica vault for cad parts only when put on release status
Description:
Hello Community,
i am planing to configure a replica vault for cad parts only when put on release status, how to tackle the task?
Check this document. You need to setup vaulting rules.
Cheers
Hari
Hi @EC_10581209
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Cheers
Hari
I tried it out but somehow it doesnt do what i want....i want only the released cad dokuments to be put in replica vault my Rule looks like this:
and when i start the scheduler the the released documents should be in the replicavault001 in the folder replicafolder001 like in the picture below
But they end up in the defaultuploadvault (cache vault) am I missing something?
Regards
Has the replication job successfully run? Because cache vault is not the final location , its a system side location before the actual replication completion.
Please check this.
Cheers
Hari
I ve managed it, needed some fine tuning in regarding the rule
