Report Template for Referenced by Parts
jenglish
Has anyone written a Report in Report Management that give you all the referenced by parts for a document? The basic report is no problem but I'm getting a little hung up on getting only the latest rev for each part.
John English
BAE Systems - ESS
Manager, Application Dev
Bldg 46-2, D45 - Endicott, NY
607-770-2034
-<">mailto:->
MikeLockwood
22-Sapphire I
(To:jenglish)
Latest Iteration is a direct pick but need to use a relatively obscure Sub Select technique to get Latest Revision.
This is primarily because Revision series can be anything.
See attached example.
[cid:image001.png@01CF5E02.B4E4C1F0]
[cid:image002.png@01CF5E02.B4E4C1F0]
[cid:image003.png@01CF5E02.B4E4C1F0]
