Report to show all drawings without Modell association
RH_9982091
8-Gravel
Hi there
i want to create a report to get all drawings that are not associated with CAD Models. I´ve tried a lot of things but didn´t get what i want. I also tried this one here CS267362  and i wanted to set the links = 0 but i do not get any results with that. Anyone who could help me with this?
HelesicPetr
(To:RH_9982091)
Hi @RH_9982091
I removed subselects, model table and reconfigure your report.
Now it reports only .drw without the links to the Models.
Hope this is what you need.
PetrH
8 REPLIES 8
I think you have to use an outer join
https://www.ptc.com/it/support/article/CS125561
Marco
And how exactly would you do this?
aaronjlarson
(To:RH_9982091)
I actually think you want the opposite of what this report does.  The example in the CS returns cases where a model is being used as a drawing reference.  If you did an outer join, you would return both models being used as a drawing reference and either models that are not used a drawing reference or drawings that reference no model, depending on the direction of the outer join.  I believe you would want to actually set up a criteria where the drawing's persist object identifier does not exist in the result of a subselect where you gather all drawings that DO have a model reference.
Yes thats what i want. I alsoe tried to set up something like EPM-Number NOTIN Subselect and than those things from the given report. But i wasn´t able to do a subselect in a subselect. Is this normal oder did i do something wrong?
aaronjlarson
(To:RH_9982091)
You are able to have nested sub-selects, i.e. a sub-select that has a criteria against another sub-select.  There must be something else going on if you are unable to set up that scenario.
So i got the nested subselect. But now i get a java.lang.NullPointerException. I think this is what exectly you meant with the outer join. I´ve never used the outer join before. Could you help me with this. This is my QML so far.
HelesicPetr
(To:RH_9982091)
Hi @RH_9982091
PetrH
Thank you. Thats what i needed. I almost had the same Solution before but i forgot to set a parameter.
