Representation Publish - Delete
Amirtharaj_K
Hi Guys,
I want to delete the bulk old representation. How we can delete it in Windchill?
Amir
Are you asking how to delete in bulk old representations? For non-current iterations? There are some add ins you might need.
https://www.ptc.com/en/support/article/CS211115?source=search
Clarify question if this is not what you were looking for.
8 REPLIES 8
Thanks for sharing @avillanueva
Can we use this same step to delete the default representation in only one iteration?
Amir
FYI:
Another option is to use PTC's command line utility.
https://www.ptc.com/en/support/article/CS62748
It isn't as popular because
  • It must be run as a system administrator from the desktop of the Windchill application server.
  • Antonio's UI recommendation is better if you need non-system administrators to do the cleanup.
  • You can purge very explicit lists of objects, but it can be difficult to build those lists.
But, if this is a one-time cleanup and really just an administrative task, the command line solution will do the job without injecting that customization into Windchill.
A third option comes from INNEO's GENIUS TOOLS for Windchill.
https://www.inneo.co.uk/en/product-development/inneo-in-house-products/genius-tools/genius-tools-for-windchill.html
The Genius Tools Publishing Bundle is mentioned on page 3 of their brochure.
https://www.inneo.co.uk/files/content/product-development/tools-and-extensions/genius-tools/genius-tools-for-windchill-brochuere-bundles.pdf
It is designed to clean up obsolete visualizations and free up file vaults disk space via automated background maintenance tasks.
Thanks for the reply @mmeadows-3 @avillanueva
How and where we can get the OID https://www.ptc.com/en/support/article/CS62748
Amir
If you mean the OID of the container, I recommend using the CONT_PATH option which is simpler. To get the OID of the representation, I recommend using a QueryBuilder report to get a list and report out its OID. Then that file can be including in this command.
Hi @avillanueva
Can you give me a small example of this?
Amir
Which part? Knowledge base has lots of examples of reports that you can mod for your needs:
https://www.ptc.com/en/support/article/CS377342?source=search
@avillanueva Thanks for both articles.
AJ
