I am kind of getting the run around from PTC on this.
Here is the question.
When you change a drawing from In Work to Released Will it triggera republish of the the wvs.publish.republishonepmdocumentchange= true
But it still does not trigger a republish. One PTC support tech said yes, the other said no.
Should it? Does yours? What do you all do?
HELP!!!
I guess I am just confused. How is this not a standetred feature? We have all of our drawings publised to PDF. The only way I know how to change the state is through PDM LINK directly not through Pro/E. So if I release my drawing I have to manually go in and say republish so I can send a drawing to production that has the words " Released ont it?
That just does not make sense?
"We had similar issues. You needed to modify some wvs properties to republish on a state change.
I believe it is described in the Business Administration Guide under visualization.
publish.republishonepmdocumentchange=true
2. In order for publish.republishonepmdocumentchange to work, a representation must exist. Ray Ray Drennen
WORKED LIEK A CHARM!!
Thank you very much. How can PTC tech support not know this?
Your solution sounds ideal for us – no Acrobat standard or product view required to see state watermark. I would love to implement this.
I have a few questions
Although we currently do embed “state" on our CAD drawings, and have learnt to live with the problems that causes personally I am in complete agreement with you and Mike Lockwood (Alcon).
When comparing now to yesteryear, I visualize lifecycle state in many ways as the PLM equivalent of applying an authorizing wet signature or ink stamp to a master printed copy of a document version….and one specific version
The viewable is our modern-day “non-editable” master printed copy. Reporting state in the CAD file is more a useful indicator that a process has been followed rather than proof.
As a company we make and buy to print (digital or paper) not CAD file. The viewable for us is therefore the resulting master output document and CAD is just a tool used to create it, so the viewable is what we should be signing….. Or rather state marking.
Regards
Darren
Mike
We experienced an array of problems related to MSI instability, MSI non-function, some serious slowdown of office app launch and sometimes even complete failure to launch office apps. Most of our efforts to get it working were with 9.1M030 XP32 and office 2003. I must admit we did not pursue these problems with PTC. There may be a simple explanation. At the time we had higher priorities and the functionality gain was not high enough.
Things have moved on now with new Windchill builds, Windows 7 and Office 2007/2010. So perhaps its not even relevant. I'm sure you have your eye on the latest related compatibilities.
One thing that bugged us was an inability to report windchill attributes in .ppt files 2003 without some custom scripting. I'd say this is more of an Office issue though.
Sorry I don't have much more to add, it's perhaps off topic anyway.
Darren
