Republishing Creo View viewable files
amansfield
Is it possible to republish and replace Creo View files created bya CAD worker? I need to change some PV settings and wanted to be able to replace the files, either manually or though some sort of a "republish" command.
We're using Windchill 10.1 M040 (Pro/Intralink 8.x)
Andrew,
Here is the process we developed
[cid:image001.jpg@01CF652A.415EAFF0]
Ray Drennen
Engineer Systems
5 Farm Springs Rd.
Farmington, CT 06032
860-676-5619 - voice
860-353-1356 – eFax
Thanks to Ray for pointing me in the right direction: all I need to do is delete the content (under Content > Representations/Annotations on the Detail page) and then I can have the CAD worker republish it.
Seems pretty obvious to me now!
In Reply to Raymond Drennen:
Andrew,
Ray Drennen
Engineer Systems
5 Farm Springs Rd.
860-353-1356 – eFax
You can manually republish all CAD representation or you can republish all representation using " Product >Utility > WVS Job Scheduler Administration".See attached screen shots
Andrew,
We use this process when a large assembly times out the publisher. We then make the representation on the desktop.
You can also do a manual publish at check-in, but you will need to update the clients recipe file to match the publisher.
Ray
