Requesting Input - CAD Driven BoM
RahulK
All,
We are planning to move from Pro/I 3.4 and Windchill 8 environment to a single PLM environment (most likely Windchill 10). We are also considering to implement CAD driven BoM concept. The idea is that a CAD model gets create in Pro/E and then upon check the corresponding bom gets published in Windchill. On paper the concept looks really good. It can basically eliminate / reduce redundant task of creating engineering bill of material.
Has your company tried to implement this concept ? If yes, what all did it take to make it a success? If you have considered but have decided not to implement CAD driven bom then what were you concerns ?
Looking forward to your feedback.
Thank you,
Rahul Kharkar
Manager - Windchill PLM Program
Novellus System Inc
proed
7-Bedrock
(To:RahulK)
Hi
We're doing something like you describe, though migrating Pro/E data from Pro/I 3.4 to PDMLink 9.1.
We're in the testing stages, and it looks like this process can work fairly well: driving PDM BOMs from CAD BOMs. The CAD items are locked in PDM, preventing change of quantity, etc, though you can add extra non-CAD items in the PDM BOM.
Would also be interested to hear from anyone further along the road - any things to look out for, points to note, etc.
Edwin Muirhead
CAD Manager, Weatherford
In Reply to Rahul Kharkar:
All,
Thank you,
Rahul Kharkar
Novellus System Inc
mfortis
2-Explorer
(To:RahulK)
I need some help trying to find out what happened to the Common Attributes pick from the Actions dropdown menu.
I was trying to edit the Common Attributes to a WTPart as a 'normal user' and noticed that the menu pick from the Action dropdown menu was not there. What I mean by 'normal user' is a user who can edit, modify, edit, rename, etc. a WTPart, non-admin.
I switched the user to the Library Manager (default admin) Role and the Common Attributes pick shows up. Can anyone help me understand why this is happening? I want to give non admin users the ability to modify common attributes without making them product administrators.
Miguel
[cid:image001.png@01CBCC34.99710E00]
What is the state of the Part they are trying to edit the Common
Attributes of?
If it's a controlled state like Released, that makes sense. If it's a
working state like In Work, then you have some incorrect Access Control
Policies.
To be able to perform an Edit Common Attributes, I believe the user needs
Modify for that Object Type at the specific state.
Steve D.
> Thanks,
> Miguel
MikeLockwood
22-Sapphire I
(To:RahulK)
Edit common attributes refers to those attributes held in common on the Master - but the user permission depends on the current state of every iteration in the object's history.
Likely at least one iteration is at a state for which Modify permission is not given to the user.
No easy way around this.
