Resource for reporting
100% helpful (2/2)
I don't know if this is the right way, but since this group is growing, maybe we could work on this document to insert useful resource for reporting.
I leave the document open, so everyone can add other useful things.
Maybe you can vote up also these three ideas:
Possibility to load SQL statements in Query Builder Report in Windchill PDMLink
Report: PTC have to share what TS do about it with their customer
Set the query limit only for Reports in Windchill PDMLink
As you can read on this discussion, Albert Anderson gave us a link about Windchill UML Model Documentation - English
Another useful document about query builder from Albert Anderson
Query Builder for Live Project Status Reports (NPI, Large Engineering Change, etc.)
Another article about UML from TS
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS188216&lang=en&source=community
I think it could be helpful also to catalogue report for argument, when it comes from other discussion, having a single source.
In bold macro argument, below title of report (in parenthesis owner of the report) and then link to download report or to TS article.
At the end of this document you can download a presentation (from Rebecca French of PTC Global Services)
It's very very old (Windchill 6.2), but it could be still useful for people who wants to take the first steps in the world of reporting.
Another document attached at the end, from Dax Williams (at PTC/User), is about creating a Windchill report interface in Excel.
TIPS and TRICKS
Documentation about relations in Query Builder in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS53948
Understanding database table relationships in Windchill to generate queries or build Windchill Reports
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS51689
How to expose Query Builder report at context level in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS42087
Automatic report creation (Mike Lockwood from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=16373
PTC Community Document: Automatic report creation
Below returns latest Iteration of each Revision (Mike Lockwood from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=11386
PTC Community Document: query builder Latest Revision
Explanation of tables that store build information between CAD Documents and Parts and the different "BuildType" values in Windchill PDMLink 10.1 (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS125790&lang=en&source=community
How to create a query builder report that accepts multiple inputs (PTC TS)
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS190138
How to enter multiple values when generating a Query builder report in Windchill PDMLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS162759&lang=en&source=community
How to get query builder report into Cognos, create report and push it back to Windchill PDMLink 10.1 (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS148905&lang=en&source=community
How to have Info*Engine query results be returned in a CSV file (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS187236&lang=en&source=community
How to hide the "Saved Reports" for particular user (PTC TS)
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS190136
How to load .QML reports into Windchill PDMLink 10.0 (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS113617&lang=en&source=community
How to load a Query Builder report exported as QML from the command line (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS187335&lang=en&source=community
How to make reports available to users in Windchill PDMLink 10 (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS182027&lang=en&source=community
How to run Query Builder report from Microsoft Excel in Windchill PDMLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS162869&lang=en&source=community
How to use the Custom Input Page for a QueryBuilder Report in Windchill PDMLink 10.1 (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS130739&lang=en&source=community
How to understand Change Management objects and their relations in Windchill PDMLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS63595&lang=en&source=community
How to use different date ranges as criteria in a Query Builder report in report manager (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS153996&lang=en&source=community
Improve Process Efficiency with Windchill Business Reporting (Vishal Arora from PTC/User)
http://portal.ptcuser.org/p/do/sd/sid=727&fid=748&req=direct
PTC Community Document: Improve Process Effiiciency with Windchill Business Reporting
List of "types" that one can select for building query builder reports (Mike Lockwood from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=10071
PTC Community Document: Types available in query builder
Multi-valued attributes display multiple times within a Query Builder report
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS53268
Overview of link objects in Windchill (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS131357&lang=en&source=community
Possibility to make reports in the query builder default to search in the current container
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS96881
Query Builder Report displays duplicate entries (PTC TS)
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS146646
Query Builder Report returns duplicate results when "Distinct" option is selected in the "SELECT Tree" (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS201994&lang=en&source=community
Query Builder Report shows duplicated row for the same Part in Windchill PDMLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS202500&lang=en&source=community
Query Builder Report Weirdness (From PTC/User)
http://portal.ptcuser.org/p/fo/st/topic=16&post=121477#p121477
PTC Community Document: Query Builder Report Weirdness
Query builder report to fetch all the values of the multivalued attribute in single row (PTC TS)
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS210938
Search on Windchill Report Builder are case sensitive though the Select criteria is "like"
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS168769
Where is the documentation for how to add Business Reporting to an existing Windchill installation?
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS115821
Windchill Business Reporting (Avinash Kor from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=9354
PTC Community Document: Windchill Business Reporting (Edited)
Windchill Database Relationships - CAD Document Parameters (Tom Uminn)
How to create bar chart report with number of records created in each month
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS223720
Use of Options in the Select Tab of Report Manager
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS35281
Information regarding how to use the Query Builder functions
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS83196
How can a report be run on a schedule and emailed to a user in Windchill PDMLink?
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS140996
Query builder report to display "Comments" column of Object
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS157262
How to allow users to see all part numbers even though they do not have access to all parts?
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS223072
How to add Info (Details Page) button and email links in query builder reports
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS227239
Query Builder Criteria Logic for getting last month
https://www.ptcusercommunity.com/thread/130187?sr=stream&ru=357802
Query builder decode function
Using Java interfaces in QueryBuilder reports
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS33057
How to retrieve the Date with no Hours:Minutes:Seconds in Query builder report using the function
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS139088
Using Java Methods in Query Builder
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS114482
How to limit Access to Report Template
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS71222
How to specify the output format of a QML report
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS131663
How to find the new name of an object when only the old name is known?
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS239797
How to retrieve attribute and its value on an object using Report Management
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS115300
What tables are global attribute definitions and values stored
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS53787
How to generate IQY query for Report Manager reports
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS47169
Database tables references for Security Audit Reporting
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS31046
How to use Concatenate function in Criteria section of Report
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS241697
In Query Builder Report how to group the results
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS162153
How to make Report Template available for use with Advanced Search in Windchill 11
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS245106
How to make a Query Builder report to fetch all the related documents for a specific BOM
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS245097
How to write a report that shows the association type between CAD Document and WTPart
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS17200
What are the steps to restrict visibility of Reports available on Saved Reports table for Users or Groups
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS244932
How to add a hyperlink to an object's Details page in Report Manager in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS82387
How to use QML reports upgraded from Windchill PDMLink 9.1 with Legacy Mode in Windchill PDMLink 11
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS246736
How to get the Checked out date of a CAD Document in a Report in Windchill
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS246873
What is the relationship between WTUser, remoteobjectinfo and remoteobjectid tables in Windchill PDMLink database
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS94037
Restrict Access by Roles to Query Builder Reports
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS249618
How to ensure Report Templates and Reports  are available for use in Advanced Search in Windchill PDMLink 11.0
ADMINISTRATIVE REPORT (User/Roles/Group/ACL's/Generic Report for different object)
Access Policy Rules by Context (Dax Williams from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=2675
Display the roles of a user (Mike Lockwood)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-35310-165974-28509/ContextTeams-Products.qml.zip
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-35310-165974-28510/User+Accounts.qml.zip
Extract policy rules (Mike Lockwood)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-55886-251502-70950/ACLs+-+alternate+approach.qml.zip
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-55886-251502-70951/ACLs.xml
Explanation of tables that store build information between CAD Documents and Parts and the different "BuildType" values (PTC TS)
Find rename objects (Lori Lee Sood)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-50412-221716-56907/FindRenamedObjects.qml.zip
Global Attribute Enumeration
https://www.ptcusercommunity.com/thread/119387?sr=stream&ru=281467
How to create a report that counts WTParts in a specific context with Query Builder in Windchill 10 (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS111896&lang=en&source=community
How to create query builder report of the empty folders in Windchill PDMLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS186510&lang=en&source=community
How to export all ACL's related to a specific user
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS123564
Last Login by user (Mike Lockwood)
User Account - Last Login Report QML
List of users (Mike Lockwood from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=18287
OIR's (Mike Lockwood)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-55759-250741-70657/OIRs.qml.zip
Policy rules (Darren Storey)
http://portal.ptcuser.org/p/fo/do/download=1&fid=23549
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS116472&posno=9&q=export%20ACL&nav=ptcproductgroupshttps://www.ptcusercommunity.com/servlet/JiveServlet/download/6144-2-69351/ACL+compare2.qml.zip
Policy rules (same format as displayed by Policy Administration applet)
http://communities.ptc.com/docs/DOC-6567
Query Builder Report listing all the Teams of which a specified Group is a Member in Windchill PDMLink and Windchill ProjectLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS201550&lang=en&source=community
Query Builder Report to fetch the reassigned task's Status Description for Project Activity (PTC TS)
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS204338
Query builder report to fetch product, role and user from role
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS189509
Query builder report to fetch "last logged in" of users
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS220318
Query Builder Report to list all objects shared between projects
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS209852
Query Builder report to show folders with associated domains
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS44018
Report with a list of Products having a specific role (Mike Lockwood)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-56841-256758-72950/Context+Teams.qml.zip
Reporting - Groups and Users (Shreyas Atre from PTC/User)
RE: Reporting - Groups and Users
Types and mapped attributes (Mike Lockwood)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-55554-249262-69944/Types+and+mapped+attributes.qml.zi…
User login date (Dax Williams from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=15121
http://portal.ptcuser.org/p/fo/do/download=1&fid=15122
Product Team Listing (Steven Rector from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=27557
How to generate a Query builder report to display Maturity History of the object
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS28221
How to get "Download" event information in Security Audit Reporting
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS135740
Query Builder report to fetch latest version of WTDocument,EPMDocument and WTPart in Library Context for particular state
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS142076
QML Report to list all the Users in Organization
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS198022
How to list Classification Nodes and their related attributes
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS220979
QML report to retrieve the Distinguished Name of all Users
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS221494
Query builder report for listing prohibit publishing objects
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS226376
Is there a way to Search Check in comments for CAD or Documents
https://www.ptcusercommunity.com/thread/130236?sr=stream&ru=364762
QML report to fetch all the objects that were renamed/renumbered in Windchill PDMLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS180898&lang=en&source=community
  •           Link to report from Dax Williams taken from other documents in the community
Action Item with Workflow Process
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111660/ACTION%20ITEM_Action%20Item%20with%20Workflow%20Process.qml.zip
Attribute Ids by Name
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111682/ADMINISTRATIVE_Attribute%20Ids%20by%20Name.qml.zip
Attribute Info
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111683/ADMINISTRATIVE_Attribute%20Info.qml.zip
Document Template Info
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111686/ADMINISTRATIVE_Document%20Template%20Info.qml.zip
User Login Audit
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8686-1-111789/ADMINISTRATIVE_User%20Login%20Audit.qml.zip
User Login Totals
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8686-1-111788/ADMINISTRATIVE_User%20Login%20Totals.qml.zip
User Specified Preferences
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111696/ADMINISTRATIVE_User%20Specified%20Preferences.qml.zip
Preferences
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111680/ADMINISTRATIVE_9.1%20Preferences.qml.zip
Quantity of Measure
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111692/ADMINISTRATIVE_Quantity%20of%20Measure.qml.zip
Report Manager Report List
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111693/ADMINISTRATIVE_Report%20Manager%20Report%20List.qml.zip
Team Template Info
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111694/ADMINISTRATIVE_Team%20Template%20Info.qml.zip
Part Version Scheme
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8682-1-111704/AUDIT_Part%20Version%20Scheme.qml.zip
Lifecycle Template Info
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111688/ADMINISTRATIVE_Lifecycle%20Template%20Info.qml.zip
Library_Product_Project Templates
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111687/ADMINISTRATIVE_Library_Product_Project%20Templates.qml.zip
Total EPMDocuments and File Size by Context
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8686-1-111791/ADMINISTRATIVE_Total%20EPMDocuments%20and%20File%20Size%20by%20Context.qml.zip
WTDocuments with File Size
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8686-1-111787/ADMINISTRATIVE_WTDocuments%20with%20File%20Size.qml.zip
How to display all WTParts with Successful ESI Distribution Target using a report
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS58679
Query builder report to fetch number of object in each Context
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS149816
Query builder report to retrieve the Team, Roles and Users associated to Variances
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS229148
QML report to generate Access Control Lists applied in a specific context
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS146799
How to get the Name and Context from any object based on the file vault file name
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS229938
How to prepare Query Builder report to generate the Product/Project/Library team members
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS28414
QML Report to generate Access Control Lists applied in a specific context
Gather a report from WVS job monitor
https://www.ptcusercommunity.com/ideas/6338
Query builder report to list all active users
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS209700
How to generate a report listing the projects and tasks where a resource is used
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS98782
QML which gives list of activities (like checkin, checkout etc) performed through both std browser
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS151749
Query Builder Report listing additional information not contained in a security audit report
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS234696
How to determine the number of WtPart in the Commonspace in Windchill
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS235473
QML report showing 'No Content association between the Drawing and WTPart'
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS227183
How to identify users listed in the Usage and License Reporting
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS107490
Family tables with instances not at same revision as generic
https://www.ptcusercommunity.com/thread/136958?sr=stream&ru=288561
Querybuilder report to display access available to users
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS162218
Report showing the OID for products, library and project
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS237841
Query builder report to fetch Distinguished Name of the user and user name
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS244704
Query Builder report to display WTParts having representations
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS247241
Query builder report to fetch Choices and their associated WTPart in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS247434
How to get a report of all Required attributes of a Classification Structure in Windchill PartsLink 11.0
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS247059
How to build a report to list all customer specific preferences in Windchill
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS249136
How to create a report listing the resource allocation over multiple Projects in Windchill ProjectLink
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS249153
How to determine if an attribute type defined in Windchill is used anywhere in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS175010
How to generate query builder report which displays user with associated subscriptions
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS23188
CHANGE MANAGEMENT (ECR, ECN, PR, ...)
Change request that has no associated change notice (Lori Lee Sood)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-50352-221824-56945/CRwithoutCN.qml.zip
Change Request Workflow Tasks (Lewis Lawrence from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=6456
Change Record Status - Open (Steven Rector from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=27558
Change Notice Report detailing Name, Description, Current Assignee, Total Days Open, Days for Current Task and Due Date (Don Senchuk)
Change Notice Report.qml
Change Activity Report detailing Name, Description, Current Assignee, Total Days Open (for parent CN), Days for Current Task, Need Date (Don Senchuk)
Change Task Report.qml
ECN and the count of WTParts for that ECN (Dax Williams from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=751
How to generate QML report for the ECN created in a 30 days using Query Builder (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS198747&lang=en&source=community
How to generate a report listing Change Notice task Comments in Windchill PDMLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS167392&lang=en&source=community
How to get "Promoted on" attribute into a Change Notice report
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS115668
https://www.ptcusercommunity.com/servlet/JiveServlet/download/423256-105730/ProblemReportComments.qml.zip
QML attached - outstanding change work items with related change objects (Darren Storey from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=24907
http://portal.ptcuser.org/x/fo/st/imagelb?fid=24908&topic=16
Query Builder report to get Affected End Item Parts added to Change Requests Affected End Item table (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS149307&lang=en&source=community
Query builder report of all the assignees of Change Notice/Change Activity in Windchill (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS179409&lang=en&source=community
Query Builder report for counting the Affected Objects in a Problem Report
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS213950
QML (total of 6) for getting affected and resulting object of CN (Shreyas Atre from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=21282
Report to return the objects in a Change Request (Shreyas Atre from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=20585
Released Part Version (Revisions) Linked to Changes (Lewis Lawrence from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=6504
How to add custom attributes to Change Notice Log report and Change Request Log report (PTC TS)
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS219369
Strictly speaking not a Query builder report, but rather a customization of the OOTB info*engine based report. Nevertheless I thought it was useful to add it here.
How to create a visual monitor report that shows open, in progress and complete Change Requests
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS224065
Query builder report to fetch problem report with associated part
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS226330
Change object Date Completed
https://www.ptcusercommunity.com/thread/129761?sr=stream&ru=5134
QML report to fetch all Change Notice and their associated Team template
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS228394
How to generate a report listing Change Request and the affected objects?
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS52010
Query builder report to list Change notice with no affected objects
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS229390
Change Notice, Change Task, Votes, Assignee, Due Date, Completed Date, Last Modified Date
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS48714
What is the relationship between Change and Changeable Object
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS106301
QML report to retrieve ECNs and their related EPMDocuments
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS239710
Change Requests and their connected Problem Reports
https://www.ptcusercommunity.com/thread/43627?sr=stream&ru=35352
How to get a list of all the ECNs in the Application for a particuar Need Date
https://www.ptcusercommunity.com/thread/133770?sr=stream&ru=36103
Query builder report (QML) to fetch problem report with part
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS226330
Report listing all Change Requests without an associated Change Notice
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS144673
Is it possible to link Problem Report and Nonconformance in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS249232
Report listing Change Request and the affected objects
EPMDoc REPORT
All Checked Out CAD Docs with Workspace and User (Mike Lockwood)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-56287-253837-71801/Checked+Out+CAD+Docs+with+Workspac…
Checked out CAD Documents (Christophe Laudou from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=3474
EPM Document and the Life Cycle Template the EPM Document is using (Shreyas Atre)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-52705-233403-62298/LCTEmplate.qml.zip
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-52705-233403-62297/LC+Join.png
EPMDoc that have been modified in a given period (Darren Storey from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=19547
EPMDocument Markup and Annotation Report by CAD Object and/or User (Dax Williams)
https://www.ptcusercommunity.com/docs/DOC-7581
Getting the related Promotion Requests of a Drawing (Mike Lockwood)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-56288-253820-71793/CAD+Doc+-+related+Promotion+Reques…
Link between EPMDocuments and WTParts (Tristan Owen)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-52705-250976-70777/EPMandWTPart.qml.zip
Link between EPM and Life Cycle template (Shreyas Atre from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=23403
http://portal.ptcuser.org/x/fo/st/imagelb?fid=23404&topic=16
How to create a Query Builder (QML) report which will list the instances associated with Generics of Family Tables (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS29111&lang=en&source=community
Numbers of  CAD documents (*.asm, *.prt) and their drawings (*.drw) [Tristan Owen]
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-39509-197193-47739/EPM_DrawingReference.qml.zip
Query to get downstream MPMLink parts from Design view WTParts (Mike Lockwood from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=14664
QML report showing ‘EPMDocument associated with the WTPart’ in Windchill PDMLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS23768&lang=en&source=community
Query Builder report that lists the size of CAD Documents and their location in Windchill PDMLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS42155&lang=en&source=community
Query Builder: Soft Type attributes for EPMDoc (NacNac Mott from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=18529
http://portal.ptcuser.org/p/fo/do/download=1&fid=18530
Query Builder report to fetch checked out objects in user's workspace
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS134496
Query builder report to fetch the EPMDocuments having annotation
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS210700
QML report showing ‘EPMDocument associated with the WTPart’ for Content association (PTC TS)
QML to find workspaces and CAD Doc's in them (Mike Lockwood)
Report from WTPart to EPMDocument including the family table values (Mike Lockwood from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=14665
Where Used (Latest Version of Objects) (Marc DeBower)
Workspace creation, last modified, etc. (Mike Lockwood)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-56658-256774-72916/Workspace+attributes.qml.zip
WTPart Object ID based on the EPM Document Object ID, Version and Iteration (Tristan Owen)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-52705-251287-70853/EPMandWTPart_IDandVersionLink.qml.…
WTParts with Associated Described By Documents (Mike Lockwood from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=14654
Query Builder report to list all the Publish EPMDocument in Windchill PDMLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS191374&lang=en&source=community
How to get a list of all family table instances with a status of "Unverified" or "Unknown"
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS40247
Query Builder Report to fetch the universally uploaded object
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS227691
How to build a report for latest version of EPMDocuments
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS33305
How to add Promoted By and Promoted On in advanced search criteria
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS55947
Anyone have a way to find nested family tables?
https://www.ptcusercommunity.com/thread/134675?sr=inbox&ru=369970
Query Builder Report which lists the user and workspace names for checked out versions of CAD Document
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS232560
How to get the latest EPM DOCrevision using Report Manager
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS184264
Family Table Report with Related WTParts
https://www.ptcusercommunity.com/docs/DOC-8798?sr=stream&ru=3370
Report to list all drawings without primary content for CAD document
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS237391
How to create a query builder Report that shows Revision History of Drawings which is a soft type of EPM Document
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS236226
Report to fetch all EPM Documents having copied from representation
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS223584
Report to generate all EPMDocument with all iteration of Lifecycle Template
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS143164
Find all EPM Documents without Visualisation
https://www.ptcusercommunity.com/thread/127349?sr=stream&ru=6342
How to build a report of objects added to workspaces
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS202379
All EPMdocuments with secondary attachments
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS249915
Query Builder report [QML] to list all Workspaces
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS250740
PROMOTION and WORKFLOW
All the outstanding workflow work items for the current user (Darren Storey from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=24898
All the workflow tasks assigned to a user in Windchill PDMLink (Binesh Kumar)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/419101-104206/%20Assigned%20Tasks%20By%20User%20Name.qml.z…
All info of interest for all Workflow Activities from a give workflow template (Mike Lockwood from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=15994
Date of PR changing states (Lori Lee Sood)
https://www.ptcusercommunity.com/servlet/JiveServlet/download/2034-49787-219926-56116/PR_States.qml.zip
How to generate QML report for the Tasks past deadline using Query Builder in Windchill PDMLink 10.2 (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS180709&lang=en&source=community
How to generate a report with events from workflow tasks in Windchill PDMLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS32218&lang=en&source=community
How to get an assigne name (in a role) from a workflow (Community)
https://www.ptcusercommunity.com/message/426199?et=watches.email.thread#426199
In which database tables are stored the workflow execution objects?
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS214035
QML report returning runtime routing list for Setup Participants from a workflow
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS210243
Query Builder report to fetch reassign information of a promotion request (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS162802&lang=en&source=community
Report to find out values of Promotion Preferences
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS215586
Report to list workflow tasks assigned to disconnected users in Windchill (PTC TS)
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS178728
Windchill Data Model for Workflow related objects in Windchill PDMLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS153902&lang=en&source=community
Query Builder Lifecycle History Example
https://www.ptcusercommunity.com/docs/DOC-8716
Report showing date of last promotion
https://www.ptcusercommunity.com/thread/135310?sr=stream&ru=263245
How to generate Query Builder report to display "Promoted on" attribute from the Maturity History table of an object
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS11566
How to retrieve records for delegation/reassignment
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS39534
Query builder report to fetch the Open Task assigned to User in a Product
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS246581
WTDOCUMENTS
How to link betweeen a WTDocument and a Package (Lori Lee Sood)
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS131346&lang=en&source=community_US
How to create a "Query Builder" report listing all "Packages" with all "Document" in "Package Content"
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS219079
How to link WTDocument and its primary content (Binesh Kumar)
Re: Report on WTDocument File
Info about the vaulted file on disk (Mike Lockwood)
https://www.ptcusercommunity.com/servlet/JiveServlet/downloadBody/3088-102-1-3664/VaultedWTDocFiles.qml.zip
QML to generate URL for document (Shreyas Atre from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=23333
Query Builder report to display WTDocuments having representations (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS166540&lang=en&source=community
Query builder report to fetch all WTDocuments with no primary content (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS167918&lang=en&source=community
Query builder report to list Documents from folder
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS208539
Report to find WTDocuments went for Approval Routing in Windchill ProjectLink
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS207521
Report to search for Documents by Effectivity
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS209206
What are the tables and joins required for generating a query builder report for Documents without any Primary Content and Attachments
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS209629
QML report to count the number of documents by different document types
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS216381
How to identify the template that was used to create documents
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS214070
Report all WTParts related to WTDocuments
https://www.ptcusercommunity.com/thread/115318?sr=stream&ru=30733
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS36007
How to create a report listing Documents Context, Name, Number, State, Latest Revision & Iteration, and Age
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS239335
File Name of a document from Query Builder
https://www.ptcusercommunity.com/message/457256
https://www.ptcusercommunity.com/servlet/JiveServlet/download/457256-119614/_Document_Search.qml.zip
Report to generate BOM report with Described By and Referenced By Documents
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS238476
Report to get the document, its state and the role responsible to complete the task
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS245051
Query builder report to fetch document which is not related to any other document
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS247264
How to build a report for latest revision of WTDocuments
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS251987
WTPARTS
How to create a Where Used report for WTParts
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS210416
How to report "Release Date" of WTPart? (from PTC/User)
http://portal.ptcuser.org/p/fo/st/topic=16&post=122009#p122009
How to write a WTPart Where Used Report (Mike Lockwood)
Report Manager: How to write a WTPart Where Used Report
How to determine the number of unique part numbers site wide (Tom Uminn)
How to determine the number of unique part numbers site wide in Windchill?
How to get the bill of material (BOM) report for latest iteration of latest version for Document Object using Report Manager (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS200270&lang=en&source=community
QML Report to list all Part Instance with its Base Part (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS203321&lang=en&source=community
QML Report to list all WTPart of Specific View in Windchill PDMLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS198025&lang=en&source=community
QML Report to to show association between Deviation and it's associated WTPart
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS205475
Query builder report to fetch the display name and internal name of classification node in Windchill PartsLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS184338&lang=en&source=community
Query builder report to find all WTParts and their corresponding PartsLink classification nodes (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS129984&lang=en&source=community
Query builder report to list WTParts from folder
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS208537
Query Builder Report to list all the OEM part which do not have AML\AVL Part associated
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS210102
Query builder report to fetch parts at level 0 in structure tab
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS215346
Which Database tables store classification attributes in Windchill PartsLink
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS172788
WTParts not been published to ERP system (Marco Tosin from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=23280
QML report to query latest version of all WTParts
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS138336
How to get a query builder report for Classification details for Parts and/or Part Structure
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS145972
Query builder report to list WTParts of particular view
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS208737
https://www.ptcusercommunity.com/message/425216#425216
How to create a Query Builder report to list all Parts that do not have Parent Part
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS223922
How to select the latest revision of a Part in a Query Builder report
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS1171
How to get a report of the URL address of WTparts
https://www.ptcusercommunity.com/thread/134395?sr=stream&ru=281467
Query to capture WTParts set to Released in the last 4 hours
https://www.ptcusercommunity.com/thread/134896?sr=stream&ru=51671
Query builder report to fetch WTParts in a specific Org that have Part Master Default unit set to "as needed"
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS232193
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS233215
Report to verify the details of changes in iterations of Part Instance using Described by Documents
http://support.ptc.com/images/cs/articles/2014/10/20163203_G4Hv.qml
Query Builder report to list the Variances reported against Parts
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS234246
SuMa - Report to list the Manufacturer associated with the specific Context Organization
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS234911
TROUBLESHOOTING
Change Requests not automatically associated with corresponding Problem Report
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS211530
Custom reports return error "wt.query.QueryException: Attribute "first" is not a member of class "class wt.org.WTUSER" after upgrading to Windchill PDMLink 10.2
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS194425&lang=en&source=community
Failed to delete some report templates from Site>Utilities>Report Management
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS185149
Generating a report from Context > Reports > Change Request Logs caused MethodServer to crash with OutOfMemoryError
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS203309
Reports imported or created at Organization level are not available for non-admin users on Homepage
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS52000
Report Builder is inadvertently removing a condition from the subquery while attempting to modify the qml with user entered data
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS186246
Using Date Picker in a OOTB Report in a browser that is not in English results a "Timestamp format" Error
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS215342
Unable to save configuration of a legacy report in Windchill PDMLink 10.2 M020 (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS188794&lang=en&source=community
When a variable is used in Select and Criteria section of Query Builder with Input Parameter, report page generated doesn't display alias name of variable in Input Parameters section
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS133386
Not able to Save reports having Chart using Organization Admin user giving secured action error
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS179575
Failed to export the results generated for Reports using Report Manager
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS204259
Information or Details page for Report Templates shows Creator attribute value as ???createdby??? where creator is not available
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS221397
Data monitor criteria filter for created on time of "Yesterday" not covering entire day
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS226634
In Report Builder, like operator does not returns exact searched string
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS224643
Report result will not be merged even select the "HTML (with merging)" in "Generate Legacy Mode Output"
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS222197
Soft types created at the organization level not available in Query Builder launched from "Site" > "Utilities"
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS227163
When searching for objects that have empty IBA with "not like" criteria, Query Builder and Search UI will give inconsistent results
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS159539
Not able to set up changeable filter criteria in Query Builder Approver Status field for attribute eventlist of type wt.workflow.definer.UserEventVector in Windchill
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS235453
Getting an error message as "Report can only be launched when Windchill Business Reporting is installed" in Windchill
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS124351
Data monitor against "Open Change Notices" report template status is "failed"
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS236920
Report to list Suppliers (Manufacturer) with their associated Documents
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS240978
Query Builder does not list the Display Name of Sourcing Status attribute values in Windchill PDMLink 11.0
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS241420
Unable to run cognos reports in Windchill 10.2
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS210583
Reports using macro CURRENT_TIME that used to work before update don’t work anymore in Windchill PDMLink 10.2 M030
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS248659
Query Builder Report to get the list of parts which does not have any related document
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS251347
Upgraded reports where attributes with an enumerated list that were previously defined in the Criteria tab no longer display the enumerated list in the drop-down in Report Builder in Windchill 11.0
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS252519
When user added java method then selected allow user to decide option all of column user is not able to generate report.
https://support.ptc.com/appserver/cs/view/solution.jsp?source=community&n=CS253057
Comments
Because the article it's growing, to help find what I add time after time, I'll add a comment.
Today this is the news.
ADMINISTRATIVE REPORT (User/Roles/Group/ACL's)
How to build a report that shows the summed file size of all objects in a context in Windchill PDMLink 10
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS187644&lang=en&source=community
How to generate a QML report in Report Manager which will show total number of documents within each container in Windchill PDMLink 9.1
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS49078&lang=en&source=community
Is it possible to generate a qml report with user-group relationship through Report Manager in Windchill PDMLink?
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS22167&lang=en&source=community
QML Listing the size of content in file vaults in Windchill
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS99514&lang=en&source=community
QML Report to list which users are associated with roles in a Team Template in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS125812&lang=en&source=community
QML How to generate a report to list all roles or members of an individual context team in Windchill PDMLink 9.1
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS43362&lang=en&source=community
QML How to create a query builder report of the OIRs defined in Windchill PDMLink 10.2
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS161288&lang=en&source=community
QML How to prepare a Query Builder Report which shows file vault information (file path and file name) that represents EPMDocuments in Windchill PDMLink 10.0
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS54021&lang=en&source=community
QML How to gather the Preferred File Server preference values for all users in a report with Windchill PDMLink 9.1
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS44007&lang=en&source=community
QML Query Builder Report listing all contexts and roles to which a user belongs in Windchill
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS40782&lang=en&source=community
QML report to fetch all the folders from product and library only in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS170849&lang=en&source=community
CHANGE MANAGEMENT
How to generate the Query Builder report to find Resulting Objects of Change Notice in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS20697&lang=en&source=community
EPMDoc REPORT
QML Query Builder report listing the Where Used for an EPM Document in Windhcill PDMLink 10.1
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS103435&lang=en&source=community
Query builder report to list task assigned to disconnected users in Windchill
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS178728&lang=en&source=community
Query builder report to fetch Promotion Request records in Windchill PDMLink 10.0 ?
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS112325&lang=en&source=community
QML Report listing all open Work Items assigned to a user within a specific context in Windchill PDMLink 9.1
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS42158&lang=en&source=community
WTDOCUMENTS
How to create a Query Builder report listing attachments information in Windchill PDMLink 9.1
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS21835&lang=en&source=community
Query builder report to fetch all WTDocuments not modified after specific date in Windchill PDMLink 10.1
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS149659&lang=en&source=community
QML Report that lists the latest versions for documents in Windhchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS26781&lang=en&source=community
WTOBJECTS
QML How to list the Name and Number of checked out objects in Windchill PDMLink 9.1
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS35948&lang=en&source=community
QML Query builder report to fetch the checked out objects which are shared from PDMLink to ProjectLink in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS180664&lang=en&source=community
QML to display list of objects shared from PDM to Project across the context in Windchill 10.0
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS143750&lang=en&source=community
WTPARTS
How to create BOM qml report to get Quantity attribute in Windchill PDMLink 9.1
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS33519&lang=en&source=community
How to get the bill of material (BOM) report for latest iteration of latest version using Report Manager in Windchill PDMLink 10.0
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS72503&lang=en&source=community
QML Report listing all Supplier Parts, OEM Parts and their sourcing status in Windchill PDMLink 9.1
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS54050&lang=en&source=community
QML Report to list Manufacturing Parts associated with a Part in Windchill PDMLink 9.1
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS40399&lang=en&source=community
QML Report to list same information as Where Used Table including Quantity attribute
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS17140&lang=en&source=community
QML Query builder report to fetch the affected End Items of Variance in Windchill
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS181651&lang=en&source=community
How to set preferred file server for another user in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS49409&lang=en&source=community
How to determine which Layouts an attribute has been added to in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS43563&lang=en&source=community
Query builder report to list the groups associated with a role in a context in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS49345&lang=en&source=community
Query builder report to fetch monthly usage report in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS150022&lang=en&source=community
Query builder report to fetch the profiles that are created at site level in Windchill PDMlink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS181021&lang=en&source=community
Query builder report to fetch exclude rule and associated option sets
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS174009&lang=en&source=community
Query builder report to fetch Include Rule and option set
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS174008&lang=en&source=community
Query builder report to fetch Options sets and choices
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS173228&lang=en&source=community
Query builder to fetch Options and associated choices
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS174007&lang=en&source=community
CHANGE MANAGEMENT
Query Builder report to fetch the related Annotation Sets of the Affected Objects in a Change Notice
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS156270&lang=en&source=community
EPMDoc REPORT
Query builder report to fetch primary role of CAD Part Instance and Generic in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS180257&lang=en&source=community
Query builder to fetch all EPMDocuments which do not have a associated WTPart
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS190123&lang=en&source=community (see also Query builder to find unassociated CADs
How to get Primary Business Object name from WfVotingEventAudit table using Report Manager
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS130932&lang=en&source=community
Query builder report to fetch completed task with approvers in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS137008&lang=en&source=community
WTDOCUMENTS
Query builder to fetch all end items WTPart for references and described by documents in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS170693&lang=en&source=community
WTOBJECTS
How to build a query builder report for searching objects that are of latest version, which are in In Work life cycle state and has been either modified or created by a specific user
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS176778&lang=en&source=community
Query builder Report to fetch set state information of all objects
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS179272&lang=en&source=community
Query builder report to fetch all the project plan activities for a particular User or Resource
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS160161&lang=en&source=community
WTPARTS
Query builder report to fetch alternate part and where used part
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS189253&lang=en&source=community
If someone has lost this discussion, I think that you can add your request about query builder here:
http://communities.ptc.com/message/266777#266777
Marco,
Thank you for providing all of this great information!
Thanks Bob.
WTDOCUMENTS
How to generate a report showing children or parents of document objects relative to document structures in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS184782&lang=en&source=community
Added Troubleshooting section.
Query Builder to find count of cached item in all Site in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS195572&lang=en&source=community
Query builder report to fetch all the Managed Collection and its Content in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS174665&lang=en&source=community
Add link to this artcile from TS
Trying to run https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS72503&lang=en&source=community doesn't show multiple level BOM.  In fact the report doesn't yield any results if I have "Reference Designator" selected to view.
I am trying to generate a multi level BOM report via query builder.
Any help is much appreciated.
-Cam
Hi Cameron,
at the moment it is not possible to get a multilevel BOM with query builder.
Added link to CS191374 (Query Builder report to list all the Publish EPMDocument) and
CS198025 (QML Report to list all WTPart of specific view).
Added link to CS198601 (What are the tables and joins required to generate a query builder Report for WTParts with Substitutes).
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS198601&lang=en&source=community
Query Builder returning blank report if attribute string value is empty (Lewis Lawrence from PTC/User)
http://portal.ptcuser.org/p/fo/st/thread=56447
http://portal.ptcuser.org/p/fo/do/download=1&fid=28415
Modify "Tips and Tricks" and Troubleshooting section
Added 091130_Reporting_QueryBuilder.ppt
Query Builder Report listing Plan Activity information for Projects contained in a Program's Network Folders in Windchill ProjectLink (PTC TS)
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS199323&lang=en&source=community
For a total n00b, or beginner, could some links be included to tutorials, or a How to get started created or something?
My responsibilities just expanded to include reporting, but I haven't the foggiest idea of where to get started.
Marc,
you can use help from Windchill where you can find a little tutorial or this two powerpoint presentations https://www.ptcusercommunity.com/servlet/JiveServlet/download/6348-50-73173/_Reporting6.2.pptx https://www.ptcusercommunity.com/servlet/JiveServlet/download/6348-50-80037/091130_Reporting_QueryBuilder.ppt
I haven't found any better material.
Sorry
Marco
The links to the ideas on the top don't work
please add it with the link tool and not with url copy/paste
Set the query limit only for Reports in Windchill PDMLink
Query Builder Report: PTC have to share what TS do about it with their custumer
Done.
Thanks Bjorn
P.S. The document is open, so everyone can add/modify information.
Added link to this discussion Query builder to find unassociated CADs
I would like to have a report to list of all the WTPart with or without associated EPM DOcument. If it is associated - It should have the Associated EPMDoc. entered.
Are the links to PTCUSER in the document all broken, or is it just me?
Marc,
I reported this problem to Ryan Kelley, appeared after the merger of PTCUser into the community site.
Look at my comment in this discussion Welcome PTC/USER members!
Can you point me to which specific links are broken so I can track them down? I'm not having an issue accessing a lot of the of the resources listed on this page.
Ryan,
seems like any link in the main document that starts with http://portal.ptcuser.org....
Marc, once I'm logged in to the PTC/USER portal I can successfully download both of those resources ("Lockwood_PTCUser2011.zip" & "query builder latest.pptx"). Are you not being prompted to login, or once you are logged in the download does not work correctly?
Ryan, I thought all this data was migrated over.  People shouldn't need to create an account or log in to PTC/USER to get to the discussions and/or data.
All of the public discussions were migrated from PTC/USER but it appears that the assets listed in this document have been linked to from the PTC/USER resource library which was not part of the scope of our migration. There are elements that are still linking to this page: http://portal.ptcuser.org/p/do/in/. There is a quick fix for this, a subject matter expert close to this document (yourself, Marc, or Marco) could download the required assets and add them as attachments to this document.
Ryan,
I can log in but then get the following message:
Same for me.
Ditto.
Bummer. If you all can get me a list of the unavailable resources I'll be sure to attach them to this document.
I noticed the same. Apparently we don't have access to that content on the old ptcuser.org site. That's sad but also understandable if they want to "clean up" as content now has been migrated - even
A while ago I manually updated the first 2 links I was interested in to point to the migrated content here on https://ptcusercommunity.org ... as an example here's screenshot of the first one from the document above:
I did the update by simply searching for "Automatic report creation" in the search box in the banner top right and pasting in the link, striking out the old link etc. Try doing the same with the text "Below returns latest Iteration of each Revision" from the next item to see how it works.
Yeah, it's a *lot* of work ... but in the end we will have:
  • All old ptcuser.org content linked to above now living locally here. I guess (hope!) links on here should be able to live on for a pretty long time
  • Still have the full context of each of the links with the original Exploder posts. IMO there's value in that compared to just having e.g. the raw .qml files etc. attached locally
What do you think guys? Is it worth e.g. taking turns or voluntering on updating the links somehow? Or do you have other ideas?
P.S.: I'm not particularly attached to the way I did the formatting. Suggestions are welcome. I just tried to do what I did to somehow leave a trace of what I did to the document (yep, that's probably a habit picked up from working too much with Windchill ;-).
P.P.S.: Kudo's to Marco Tosin‌ for collecting the document above in the first place. It has become a very valuable ressource.
Ryan,
I copied the document above and took out everything but the links pointing to the User Portal.
-marc
TIPS and TRICKS
Below returns latest Iteration of each Revision (Mike Lockwood from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=11386
List of "types" that one can select for building query builder reports (Mike Lockwood from PTC/User)
http://portal.ptcuser.org/p/fo/do/download=1&fid=10071
Query Builder Report Weirdness (From PTC/User)
http://portal.ptcuser.org/p/fo/st/topic=16&post=121477#p121477
http://portal.ptcuser.org/p/fo/do/download=1&fid=25178
CHANGE MANAGEMENT
EPMDoc REPORT
WTDOCUMENTS
WTPARTS
Marc - can you confirm you're getting an authorization error on all the links provided above? I'd like to minimize the amount of changes we make to the original document, so tracking down exactly where you're seeing errors is critical.
Ryan Kelley‌, I checked them all and removed one that worked, and found one other that pointed to the PTC Tech Support Site and removed that one too.  The remaining links all fail to reach the appropriate destination.
marc
Marco, the second to the last one - OIR export - is supposed to be included in the next major release in December (10.3 / 11.0).
Thanks again, Marc. I've followed up with the team who maintains the PTC/USER portal to ask how we can alleviate this permissioning issue. Stay tuned.
Thanks for your info Tom.
Ryan Kelley‌  any status update available concerning this?
I ran into a situation today where the solution was listed in the document. but unavailable due to the broken links.  Very frustrating.
- marc
Hey Marc - I've reached out to the administrator of the PTC/USER site to see if they can fix the user permissions on their ends but have yet to hear back. I'm just ramping up after a week on vacation and will reach out to them again.
Ryan Kelley have you been able to get this fixed yet?
Thanks!
Version history
Last update:
‎Sep 19, 2014 05:38 AM
Updated by:
Labels (1)
