I think it can be acheived using access controlled policies (ACLs).
Provide deny access to SoftType in context/container where its not applicable
Or
Provide deny access at level where this Object is defined (Site/Org) and provide Create/modify/etc access in desired context/container.
Avinash
Hi Mike,
If ACL's are applied correctly (Create/Modify/etc deny access by Role) then Soft Type or Object will not apear on User's create window.
Avinash
In Reply to Mike Lockwood:
ACLs work but the user doesn’t see the result until they select Finish on the New Doc wizard.
Using OIR’s with Lifecycle has the advantage of removing the type from the list of types to select.
Hi Mike,
Please refer below example (tried on 10.1 M040)
After adding this ACL user (wcadmin) was not able to see Document Type into Create Doc window
I hope this example will help.
Avinash
My approach to accomplish this is to define most ACL's on ORG level (or as high as possible in the hierarchical structured domains), except the 'allow create' rule. This rule is only defined where I want users to have the possibility to create that particular softtype. Quiet straightforward, with one caveat, being the restriction to move objects.
I would be interested to know what the life cycle workaround brings as extra.
Regards, Hugo.
<< ProE WF5 - PDMLink 10.1 M040>>
