Retrieving a Attribute from an Object Using an Expression in a Workflow
SOLVED
Re: Retrieving a Attribute from an Object Using an Expression in a Workflow
Hi Jeffrey ,
I want to update (revise) an existing document. I have the code for revision.
After revising the document and before using the persistencehelper.save i use the above mentioned code to update iba values on the new version. But that results in two values on the iba.
for e.g
Doc A.1 - Attribute1=123
Doc B.1 - Attribute1=123,345
I also see the values from previous revision. Can you help me in clearing out the Iba values before i store new values.
Because the above scenatio gives a me exception on single value constraint attributes.
Also the Persistencehelper modify does not work as it asks to first checkout the object.So i use the code above first and then the SAVE method before storing the object for the first time in DB.
I am not sure these methods are supported in that use case - why don't you update the values after the revise?
Hi Jeffrey
Once the object is persisted then the PersistenceHelper.manager.modify(my_persistable); api gives a error.
Object is not ready for modification please check out the object. And i dont want to iterate the object.
I have raised a case with PTC for this.
getting this error when checking syntax
Checking Syntax...
C:\ptc\Windchill_10.2\Windchill\temp\WfExpression831571.java:39: error: cannot find symbol
IBAValue_VM_Name= VM_Name
symbol: variable IBAValue_VM_Name
Note: C:\ptc\Windchill_10.2\Windchill\temp\WfExpression831571.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
1 error
Syntax check complete.
Hi Zane,
Without seeing your full code I cannot comment too much on your error.
It seems though that you are trying to use a variable "IBAValue_VM_Name" which you have not declared anywhere in your code and this is the source of your error.
Toby
