Revise many parts at once
Ilan_Mor
11-Garnet
Hi
Is there any option to Revise many parts at once in Windchill ?
Thank you
Chris3
20-Turquoise
(To:Ilan_Mor)
Add all the parts you want to a workspace and then you can revise them all from there. You can also setup the collection to pull dependents (children) as needed.
Chris3
20-Turquoise
(To:Ilan_Mor)
It may help to know more info, about the background of this request, and what you're trying to do, in revising multiple parts, but as already pointed out this can be done from the Workspace, and revising multiple parts, is also available from the Folder Contents table.
Depending on your need, one can also use Import from Spreadsheet, to revise multiple parts, via that method as well.
Mike C.
Revise many can also be done in the context of a Change Task giving  you 3 locations to perform this.
