Running CPS on Rehosted Test Windchill(11.1 M020 CPS 27) failing
SJ_10261989
Running CPS on Rehosted Test Windchill failing with error
INFO 2024-10-16 09:58:29 - BUILD FAILED
INFO 2024-10-16 09:58:29 - D:\ptc\Windchill_Apps\Windchill\bin\installModules.xml:672: The following error occurred while executing this line:
INFO 2024-10-16 09:58:29 - D:\ptc\Windchill_Apps\Windchill\bin\ptcarchive.xml:85: Repository windchill-test.marine.net.int does not exist
INFO 2024-10-16 09:58:29 - at com.infoengine.administration.packaging.AntInstaller.execute(AntInstaller.java:225)
INFO 2024-10-16 09:58:29 - at com.infoengine.administration.packaging.AntInstaller.execute(AntInstaller.java:175)
8 REPLIES 8
Hi @SJ_10261989,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
SJ_10261989
(To:SJ_10261989)
Hello Catalina,
Thank you for the Response,
Sure will try to get more details about the issue and attach it in the Post as text and screenshot.
Surender Kumar
SJ_10261989
(To:SJ_10261989)
Dear PTC community
Added Further details for Some of the Windchill Property files.
Kindly assist.
Surender Kumar
Without digging in too deep, this might be a case for a PTC Tech support ticket. Be careful sharing such detail information of your environment. This site is public. Let's start with some basics. You mentioned this server is a rehosted instance. Did the rehost work? Does it function without issues prior to you trying to apply the CPS? The line about the repository being missing might be pointing to a misconfiguration from rehost. Is "windchill-test.marine.net.int" from Production or the test server?
SJ_10261989
(To:avillanueva)
Hello @avillanueva yes i Raised the Ticket with PTC but PTC tech Support said the Windchill version is out of Sustainable support project and they want assist on it. and Suggested to reach out to PTC community for assistance.
Yes the Windchill is Still up and Running. And Windchill-test.marine.net.int is from Test Server.
Surender Kumar
BenLoosli
(To:SJ_10261989)
Let me get something fixed in my mind.
You have the original source system still up and running Windchill 11.1 M020 CPSxx
You did a rehost to a new server with Windchill 11.1 M020 CPSxx.
Did the rehosted target system run with Windchill 11.1 M020 CPSxx?
You then tried to apply the 11.1 M020 CPS027 patch to the rehosted target system.
This where the error occurred.
SJ_10261989
(To:BenLoosli)
Hello Ben
Your tight except the fast that the current which version at source and target is CPS 27 and now I'm trying to deploy CPS 30 on test server (rehosted target server).
Surender Kumar
BenLoosli
(To:SJ_10261989)
Does the rehosted test server start and run Windchill at 11.1 M020 CPS27?
