Running PSI on windows 2019
RW_10682860
We are running PSI (windchill 12.1.2.0) on windows 2019 server (a clean vm), the installanywhere shows up at 100%, however that ends there. I can see the "wscript" in the task manager which gets terminated/closed after few minutes.
Looking at gpo, policies, all looks fine - any insight what it could be?
LAX_VM is set right, VC++ redistributables look good, enough disk space. All zips looks not blocked
Thank you
Raj
Thank you all. It is resolved and the solution
Went to Java 11.0.7 instead of 11.0.2 and it worked well. However, there were no specific errors and that was tricky kinda!
Thanks all again for the replies
Raj
Make sure the exe files are not blocked as well (checkmark unblock on the properties for any exe that shows it). Also, try running the PSI from an admin command prompt
BenLoosli
(To:RW_10682860)
Are you doing the Setup.exe with Run As Administrator option?
We have found that as Windows gets more and more hardened, that sometimes you have to run an administrator command prompt to successfully run setup.vbs / setup.exe
Raj
