SQL Exception in starting windchill
RK_10805837
I have updated the current windchill installation 12.0 with CPS15 with the modules ESI and project link. However, when installing through PSI I didnt select create database schema option and now I get the SQL exception of the table does not exist.
The Server Manager, Method Server and Backgroung Method Server logs are generated but the windchill doesnt start. I am attaching the error snapshot here. Kindly provide resolutions if any,
Ramsha
So, is this a new installation? Just clarifying that you were not simply adding modules or upgrading to CPS15. If this is a new installation, you should be able to recreate the database and schema separately.
This is covered in help documentation here:
https://support.ptc.com/help/wnc/r12.0.2.0/en/#page/Windchill_Help_Center%2FWCInstall_CreateDataSchema.html
HelesicPetr
(To:avillanueva)
Or
if it is new installation and you know you did something wrong, remove the current installation and start new installation instead of trying to correct the actual one.
It is easier.
PetrH
Hi ,
The error was due to few sequences which were not correct. After running some SQL queries , the problem was resolved.
Ramsha
