Saving a design iteration in Windchill
Blackhawk
Is there a functionality in Windchill 11.0 where you can save a snapshot or iteration of your assembly where all the associated parts and drawings can be saved at the same iteration.
For example, if I had an assembly with parts and drawings where I want to save that design as-is so that it can be restored or retrieved in the future.  This would be in the case that the design continues on a new course, that ends up not working out.  I would like to go back and retrieve the design iteration that I saved previously.
You may want to look at Managed Baselines.  Can use to access a design as it was at some previous time.
Likely do not want to artificially iterate all objects for this purpose.
Yes, baseline was the term that I was looking for.  That seems to be what I am looking for.  If anyone has any good training links on how to create and retrieve baselines, that would be greatly appreciated.
