Saving an Annotation Set to Windchill from Creo View fails
Hozaibergen
Version: Windchill Below 11.0
Use Case: Saving an Annotation Set to Windchill
Description:
Saving an Annotation Set to Windchill from Creo View fails with the message "The view could not be saved. Try saving again under a different annotation set name."
Help me fix it. (
case 136054 is blocked for me.
Cause
Resolution
Cause
Resolution
big thank you)
This will be very useful to me.
Hi @Hozaibergen,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
