Hi all
Trying to get ProE Wildfire 3.0 and ProE Intralink 3.4 running on Windows 7 a part of a migration from Windows XP to 7
When I enter Intralink login credentials, and click OK, I'm seeing
'Schema is not compatible'
'Check that the Pro/Intralink client, data server, and file server are all the same manufacturing code. This may be found in the <loadpoint/version directories.'
The loadpoint is c:\ptc\proiclient3.4
I have no .psf file, and when I run ptcsetup.bat it fails to generate one.
Any ideas?
