Search for multiple items
ptc-859099
Is there a way to search for multiple items in windchill 9.0? I understand that it is possible to enter wild card characters to find parts but that is rather limited to a particular range and also gives me more results that I am wanting. In intralink 3.3 if I wanted to search for file name 111.prt and 222.asm I could simply type in "111*;222*;" (without the quotations) and it would find both items. How can I do this same thing in windchill 9.0?
Darrell
(To:Darrell)
In PDMLink 9.0, I recently figured out how to search for multiple objects using a semicolon (Boolean OR) and thought I would share it: You can do it in the name fields (name, number and filename), but you can't use a semicolon in the keyword field.
19 REPLIES 19
Nathan, I tried to get a answer to the same question a few weeks back and was told by PTC that this particular functionality does not exist in windchill. They suggested that a product improvment request be made to have this functionality added in future releases. Sorry for the bad news hope this helps.
Thanks, I got this same answer from someone else but was hoping there was someone out that knew something he didnt. Guess not...
You can do it using "Advanced Search" - see the example screenshot. It's Windchill 8 screenshot, but in Windchill 9 it works the same.
Where is the screen shot?
Here we go (updated the previous message)!
Thank you very much. Going a bit off topic for a moment, I see that under the buttons for delete, add to project, move, etc. it has a description of what the button is for. Is it possible to get that in windchill 9?
I will have a look @office tomorrow.
I found it, I overlooked it in the preferences.
In a standard search, you can separate mulitple items with a semi-colon. Ex. 12345.*; 6789.*. We have been using 9.0 for a while and have always been able to do the multiple item search.
I have tried that before and just tried again, it doesnt work for me.
I've tried the semi column also and it doesn't seem to work.
Darrell
(To:MMelanson)
I have tried the comma, semicolon, space and everything else I could think of and none of it worked in PDMLink 9. The selections below the keyword box: With All of These Criteria and With Any of These Criteria sure make me think its possible. I never could figure it out though.
Darrell
(To:Darrell)
AWESOME. Did you figure out how to do an "AND" search where the order doesn't matter? for example if my part is named screw, machine, flat head, phillips, m4x10
I can do my search as follows *screw*m4* but sometimes the name in Windchill would be "M4x10 machine screw" so my search would not capture this part.
Darrell
(To:MMelanson)
You have to use advanced search. On the advanced search page, leave keyword blank, select
Hi i am trying a search scenario and need some help on that.
Select with all of these criteria.
Attribute1 is an iba attribute on WTdoc with a legal list constraint.
Attribute 2 is simple string type attribute.
My criteria is
Attribute 2 = 123*;890*
Attribute 1=N15;N14
I want an AND between Att1 and Att2 and an OR for values of Att1 and Att2.
I can do OR for values on Att2 by specifying a ; symbol between more than one values but for Att1 it shows me a list of values (drop down). So i can now select only one value.
How can solve this issue.
I have set the property entry "com.ptc.windchill.search.client.overrideAndOrOperator" to true and want to use it as true always.
Because if i set it to false or dont use it then if i use following criteria
Attribute2=123*
Attribute2!=*xyz
it does not search for (Attribute2='123')&(Attribute2!=*xyz). It puts an OR in between and gives me wrong result, even if i have selected With all of criteria.
cgorni
(To:Darrell)
In fact semi-colon cannot be used in Keyword search if the Index Search is enabled, see CS78425
HelesicPetr
22-Sapphire I
(To:cgorni)
Hi @cgorni
If you use index search use the semicolon in a specific parameter column do not use keyword column . It works.
I didn't read previous answers 😄 so I just repeated what has been mentioned.
PetrH
