Search for "Checked Out By"
SOLVED
Re: Search for "Checked Out By"
Yes, but only one at a time, as I discovered.
This reminds me of the famous BF Skinner pigeon experiment into conditioning superstitious behavior.
http://psychclassics.yorku.ca/Skinner/Pigeon/
"The conditioning process is usually obvious. The bird happens to be executing some response as the hopper appears; as a result it tends to repeat this response. "
I think the people who conducted this experiment then went on to write the Windchill software.
I might add, that if I select "Undo Checkout" from the drop-down "Actions" menu, then it doesn't work. But if I select the file and right-click to get to "Undo Checkout" then it does work.  I feel more and more like a pigeon in a laboratory trying to work out which random bit of head-bobbing gets me the food.
You *could* write some sort of workflow connected to a User Termination Object (softtype of a Problem Report). That would actually be kind of neat.
