Search on ProE Parmameters
davehaigh
I just noticed I can't search on ProE parameters since upgrading to 9.0.
Any ideas what setting got changed that prevents this?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
make sure your attributes have their Logical Identifier set in the Type
and Attribute manager
I already have my ProE Parameters mapping to PDMLink Attributes as shown in the information page on an existing file. (Attached as untitled-3a.jpg)
However when I got to advanced search and search for Workgroup Manager CAD Documents,
The Criteria I can search on doesn't show those attributes. (See attached untiltled-4a.jpg)
Is there some wt property or preference that needs to be set to allow you to search on these attributes?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
All -
Was there ever any resolution on this question? I have a user group that is interested in being able to search by model parameter, and I'm hoping that's something I can set up for them without too much trouble. We are on PDMLink 9.1 (M050).
Thanks in advance!
Chrystal Johnstone
Red Dot Corporation
Chrystal,
If I understand the question (I didn’t see the original post) as long as the parameters are designated at the part level and are evident in PDMLink you can use the advanced search and set the particular parameter to search through.
Hope it helps,
Bob Lohbauer
