Searching for CAD parts by specific attributes and where used
TomU
Is there a way create a where used search that takes into account criteria for the object being searched for as well as criteria for the object it is used in?
Find all *.prt where
Category = 507 and
Sub_Category = 060
Used in *.asm where
Category = 337
Also, does Windchill have knowledge of the number of times a part is used inside an assembly. (We are not using WT parts.)
This is for Windchill 9.1 M050. Thanks!
Tom Uminn
Engineering Systems Analyst
trans-matic Mfg.
616-820-2499
-<">mailto:->
RandyJones
(To:TomU)
> Category = 507 and
> Sub_Category = 060
> Used in *.asm where
> Category = 337
Don't know about an easy ootb method for this one. It would be possible to write a jsp page that
would do the following:
1. find all *.asm where Category = 337
2. loop thru the components (structure) of each assembly looking for prt's in which Category = 507
and Sub_Category = 060
3. output the "matching" prts
Yes. Go to the details page for the assembly and then select "Structure".
> *Tom Uminn*
> *trans**-matic*Mfg.
> 616-820-2499
> - <">mailto:->
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
RandyJones
(To:TomU)
> Category = 507 and
> Sub_Category = 060
> Used in *.asm where
> Category = 337
> *Tom Uminn*
> *trans**-matic*Mfg.
> 616-820-2499
> - <">mailto:->
Randy Jones
1525 E North St
PO Box 5060
email: -
Phone: 785-823-3276
Fax: 785-667-2695
