Searching for WTPartDescribeLinks
rfranco
7-Bedrock
I need to run a search for specific WTPartDescribeLinks from a checked out part.
The following line isn't working for me. I get an error stating the iteration must not be null. I believe the method has been deprecated.
//QueryResult qrLink = StructHelper.service.navigateDescribes(checkedOutPart, WTPartDescribeLink.class, false);
I have also tried
QueryResult qrLink = PersistenceHelper.manager.navigate(checkedOutPart,   WTPartDescribeLink.ROLE_AOBJECT_REF, WTPartDescribeLink.class, false);
But I am getting a Null Pointer Exception
Is there another way of running a search for these describe links or am I doing something wrong?
Any thoughts would be very much appreciated. Thanks
Ryan
rfranco
7-Bedrock
(To:rfranco)
Got it sorted now, thanks guys.
I used,
QueryResult qrLink = wt.part.WTPartHelper.service.getDescribedByWTDocuments(checkedOutPart, false);
Also the null pointer exception was due to a variable in the wrong place (inside a loop).
bsindelar
(To:rfranco)
Ryan,
Are you looking for a WTPart<>EPMDoc link or a WTPart<>WTDoc link?  And does it have to be through APIs or Java methods?
There may be ways to do this via the DB ... and thus through QueryBuilder as well.
jmomber
(To:rfranco)
When I run this on a part in my system (not checked out), I get links returned:
QueryResult qrLink = PersistenceHelper.manager.navigate(p,   WTPartDescribeLink.ROLE_BOBJECT_ROLE, WTPartDescribeLink.class, false);
~Jamie
rfranco
7-Bedrock
(To:rfranco)
I used,
