Can someone please help me, I have this in the logs:
2017-02-08 12:15:26,844 INFO [main] wt.server.manager.startup - Starting ServerManager
2017-02-08 12:15:26,845 INFO [main] wt.server.manager.startup - JVM id: 160
2017-02-08 12:15:26,845 INFO [main] wt.server.manager.startup - JVM: Oracle Corporation, Java HotSpot(TM) 64-Bit Server VM, 1.8.0_92 (25.92-b14), 64-bit
2017-02-08 12:15:26,845 INFO [main] wt.server.manager.startup - OS: Windows Server 2012 R2, amd64, 6.3
2017-02-08 12:15:26,845 INFO [main] wt.server.manager.startup - Host: WIN-9U6A5RRLNG0 (172.31.26.169)
2017-02-08 12:15:26,845 INFO [main] wt.server.manager.startup - java.rmi.server.hostname: 172.31.26.169
2017-02-08 12:15:26,845 INFO [main] wt.server.manager.startup - wt.rmi.server.hostname: ec2-35-156-59-114.eu-central-1.compute.amazonaws.com
2017-02-08 12:15:26,846 INFO [main] wt.server.manager.startup - HeapDumpPath: D:\ptc\Windchill_11.0\Windchill\heapDumps
2017-02-08 12:15:26,847 INFO [main] wt.server.manager.startup - Class path =
D:\ptc\Windchill_11.0\Windchill\codebase
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\archiveClientWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\archiveServerWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\archiveWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\CounterPartWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\dpimplWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\dpinfraWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\Gantt.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\GanttExplorer.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\ie3rdpartylibs.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\ieWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\install.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\jmxcoreWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\jviews-chart-all.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\jviews-framework-all.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\jviews-gantt-all.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\mksapi.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\mpmlWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\mylyn-integration.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\pdmlWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\pjlWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\ProjectManagement.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\prowtWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\ptlcWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\reqlWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\restWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\rialtoWeb.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\RMWebServices.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\TwxIEWebService.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\wc3rdpartylibs.jar
D:\ptc\Windchill_11.0\Windchill\codebase\WEB-INF\lib\wncWeb.jar
D:\ptc\Windchill_11.0\Windchill\lib\esi.jar
D:\ptc\Windchill_11.0\Windchill\lib\mpml.jar
D:\ptc\Windchill_11.0\Windchill\lib\pdml.jar
D:\ptc\Windchill_11.0\Windchill\lib\pjl.jar
D:\ptc\Windchill_11.0\Windchill\lib\reql.jar
D:\ptc\Windchill_11.0\Windchill\lib\servlet.jar
D:\ptc\Windchill_11.0\Windchill\lib\wnc.jar
D:\ptc\Windchill_11.0\Java\lib\tools.jar
D:\ptc\Windchill_11.0\Windchill\tomcat\bin\bootstrap.jar
D:\ptc\Windchill_11.0\Windchill\tomcat\bin\tomcat-juli.jar
D:\ptc\Windchill_11.0\Windchill\srclib\wnc\WtAsmAgent.jar
2017-02-08 12:15:26,857 INFO [main] wt.server.manager.startup - Registry created: RegistryImpl[UnicastServerRef2 [liveRef: [endpoint:[172.31.26.169:5002,wt.boot.WTRMIMasterSocketFactory@1e240](local),objID:[0:0:0, 0]]]]
2017-02-08 12:15:26,888 INFO [main] wt.server.manager.startup - ServerManager created: ServerManagerImpl[UnicastServerRef2 [liveRef: [endpoint:[172.31.26.169:5002,wt.boot.WTRMIMasterSocketFactory@1e240](local),objID:[0:0:0, 5002]]]]
2017-02-08 12:15:26,891 INFO [main] wt.server.manager.startup - ServerManager bound in registry.
2017-02-08 12:15:26,898 INFO [main] wt.manager.CacheMasterNegotiator - Cache master stub name: CacheMaster
2017-02-08 12:15:26,899 INFO [main] wt.manager.CacheMasterNegotiator - Using low-locking algorithm
2017-02-08 12:15:27,869 ERROR [main] wt.manager.CacheMasterNegotiator - Failed to acquire JDBC connection
java.sql.SQLException: ORA-01017: invalid username/password; logon denied
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:450)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:392)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:385)
at oracle.jdbc.driver.T4CTTIfun.processError(T4CTTIfun.java:938)
at oracle.jdbc.driver.T4CTTIoauthenticate.processError(T4CTTIoauthenticate.java:480)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:655)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:249)
at oracle.jdbc.driver.T4CTTIoauthenticate.doOAUTH(T4CTTIoauthenticate.java:416)
at oracle.jdbc.driver.T4CTTIoauthenticate.doOAUTH(T4CTTIoauthenticate.java:825)
at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:596)
at oracle.jdbc.driver.PhysicalConnection.<init>(PhysicalConnection.java:715)
at oracle.jdbc.driver.T4CConnection.<init>(T4CConnection.java:385)
at oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java:30)
at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:564)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:208)
at wt.pds.StandardDataSource$2.getConnection(StandardDataSource.java:156)
at wt.pds.StandardDataSource$ConnectionRetry.execute(StandardDataSource.java:399)
at wt.pds.StandardDataSource.getConnection(StandardDataSource.java:159)
at wt.pds.StandardDataSource.getConnection(StandardDataSource.java:86)
at wt.manager.CacheMasterNegotiator.getNewConnection(CacheMasterNegotiator.java:859)
at wt.manager.CacheMasterNegotiator.start(CacheMasterNegotiator.java:2268)
at wt.manager.ServerManagerMain.startServerManager_internal(ServerManagerMain.java:391)
at wt.manager.ServerManagerMain.run(ServerManagerMain.java:299)
at wt.manager.ServerManagerMain.main(ServerManagerMain.java:229)
2017-02-08 12:15:27,879 FATAL [main] wt.server.manager - ServerManagerMain abort
Hi Amaar,
Make sure 'database user' and 'database password' are correctly set in db.properties.
Hi Amaar,
Solved: I had to redefine my encrypted passwords.
For those with the same error: From a Windchill Shell use the "xconfmanager -d <encrypted.password> " command to verify that they are correctly defined.
