Good morning all,
Please take a look at the attachment. Has anyone out there gotten the error? I thought I had this fixed and all was good for several weeks but it popped up again this week.
In most cases the user only needs to select NO on the "Do you want to switch to offline mode?" and then click on the OK button on the next pop-up. A select few need to end task for Pro/E which takes them totally out of the PDMLink and the session in their workspace. This issue comes up only after starting a session of Pro/E logged into PDM workspace.
If you had gotten this issue, what did you do to correct it?
Rex Snider
CAD Systems Administrator
TTI Floor Care North America
440.996.2310
<h3/>
