I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
Service impact attribute is getting displayed in the muti part creation window
Hi @RC_10659261,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
Is the multi part creation window working differently than when creating a single part?
The multi part creation window allows for different views. The admin can customize the default view as needed, or even create new views. If the attribute is required and a default is not set, it may cause errors if the attribute is not visible.
