OK, so I would like to same a click for every CN that Doc Control has to create from every CR.
Anyone know how to set Propagate Information as checked by default?
I have set the default for Change Tasks (Reviewer Required, or Obsolete).
There is a preference which you can set in Change Management preferences.This will default the propagate information to yes
Thank you Binesh. ![]()
Now that's odd. When the CN and Task are created the default selections are populated but after the CN is created and ready to submit they all become unselected?
