Hello
I want to know the command in OIR to set the enditem attribute automatically to yes in creation of a subtype.
By the way i can see a blank value above Yes. What happens when you select it?
I am not sure, how you can achieve using OIR, but there is a simple way to do it using Type and Attribute Manager.
Below article explains how you can do it.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS129431&art_lang=en&posno=1&q=end%20item%20default&source=sear…https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS63679&art_lang=en&posno=3&q=end%20item%20default&source=search
Hello Thanks for the Answer
I want the attribute EndItem will set always setting to Yes for this subtype ( the creator can t modify it on creation or edit)
regards
Hi
I tried to follow the instruction in the article, but I can t set the default attribute (endItem) of the part master to blank. There are only 2 options: yes or no:
What windchill version you are using? I was able to do it on 10.1 M020 without any hitch.
