Set or change window size and location WGM 11.1 M020
nstajduhar
Hopefully someone can assist. In our previous version of WGM 11.0 our users were able to move and resize action boxes to whatever monitor they wanted and resize them they way they want and it would save the location and size. This is no longer the case with 11.1. Whenever an action box is opened it is automatically put in the top left of monitor 1 unlike previous versions we were able to move them to monitor 2 and once done with them it would save that location and when it was brought up again would appear in the same location it was left. Is this possible in 11.1 M020?
Hi nstajduhar,
You may want to open a Support case, with the WGM support team, so they can look at this.
Is it possible you may be seeing this known issue, with opening info page boxes via the (i) button, and mid-mouse button?
https://www.ptc.com/en/support/article?n=CS300733
Some more context about the particular actions being done, may help clarify if you are hitting a known SPR or not.  Support should be able to assist in this.
Hi nstajduhar,
