Hi All,
I have created a new soft type of a document which is for requests of various types. I have set up an OIR so that it is created in a certain folder. The only problem is the user has to select the "Autoselect Folder" option under the location when they are creating a document of this type. Is there any way to make it so that they do not have the option and it is automatically created in the folder I have specified?
Toby
You can manipulate in the OIR constraints:
- What a user sees
- What the system automatically does for folder assignment
See PTC's details in on-line help about OIRs
- What a user sees
Hi Mike
Please could you point me in the right direction to find the online help you refer to?
If you have a link to the page that would be great as I am struggling to locate the information needed to manipulate the OIR constraint to set autoselect folder as the default
Many Thanks
Hi, Kelly,
I believe you can find the information you're looking for in the Windchill Help Center. For more information about OIRs, you could start with this topic: http://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=ObjRulesChp_Intro&action=show.
For information about customizing attribute display (e.g., the UI behavior of the Location attribute), check the Attribute Customization topic: http://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspxid=WCCG_UICust_PresentInfoUI_AttributeHandle&action=show
I hope you find this information helpful, and I'll welcome any feedback.
Jane
Hi there,
I have exactly the same issue. Unfortunately those links do not work anymore.
Does anyone have a working link or some lines of code?
Cheers
Matthias
Hi Matthias
Please see the below article which helped me to achieve this
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS21908
Hope this helps. Let me know if you need anything further
Kind Regards
Kelly
Hi MikeLockwood,
While creating new object I want autoSelected : "Select Folder" radio button AND path inside that text area should be pregenerated .
So now situation is "Select folder" radio button is selected but folder path I want inside that text area it is not updating
So How can we achieve this .
You comment the below lines in OIR for that object type:
<!-- <AttrConstraint
id="folder.id"
algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints"
ignore="false"
force="false"
final="false">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue">
</Value>
</AttrConstraint>
Add new Lines as below:
<AttrConstraint id="folder.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue"/>
<Value algorithm="com.ptc.core.rule.server.impl.GetRendererConstraint">
<Arg>SelectGeneratedFolderByDefault</Arg>
</Value>
</AttrConstraint>
Make the chnages in Default folder path and add your required path as below:
<Arg>/Default/<Folder_Name></Arg>
I have done it for Promotion request and it worked without any issue.
Devidas,
I'd like to do exactly what you've done for the Promotion Request, however I do not know where or how to get to the file/setting where I'd add in the additional code. Could you describe how I get there?
Marc
You need to use the site/org admin utilities and edit the OIR rule for the setting you want to change.
So at site level>utilities>object initialization rules administration? Once there I have a long list of different OIR's, with the right-click choice to edit, download and a few others. It appears that the way to make a change is to 'download' the current rule, make changes in some kind of xml editor and then upload the modified rule by using the 'edit' right-click option?
Marc
That is correct.
The changes I made to the OIR rules pertain to which folder I store promotion request and change management files in. These are stored by year, so I have to make the change to my OIRs yearly.
Store your modified OIR files in a dedicated directory for 3 reasons: 1) you know which OIRs have been modified, 2) you don't have to download it again and 3) you can make future changes and just Edit-Browse to install.
