Setting the default primary server in Windchill 10
lholmberg
Hi:
Everytime I launch ProE I need to go to the Server manager and set the primary server (it defaults to <no server=">). Is there a config option or something to set it so it automatically sets the server every time I launch Wildfire 5/Creo Elements Pro?
FYI I have set it to log into Windchill on the embeded browser everytime I launch ProE.
Thanks.
jtjohnson
(To:lholmberg)
Hi Logan
Try this:
dm_remember_server yes
Jeff
This isn't OOTB behavior. Your config files are most likely messing with these. The setting below should do the trick. A good troubleshooting processes always starts with stripping your configuration files out (pro, sup and win) and seeing if that makes the difference.
[cid:image001.gif@01CD753E.D01D5DA0]
Steve Vinyard
Application Engineer
