Setup participant activity
  • January 18, 2013
  • 2 replies
  • 4819 views
Hi
My problem is-
I have a setup participant activity.there are three roles for which i have to assign participants .For eg. if i assign participant for role A and role B.But if i dont assign anyone for role c.The task is going to the creator .i dont want that if no person is assigned to a role.I dont want it to go to anyone.How should i go about it??
GregoryPERASSO
Hello
you can add this code in the "complete transition" of your SetUp participant task, or in a conditionnal robot just behind
wt.workflow.engine.WfProcess wfprocess = ((wt.workflow.work.WfAssignedActivity)self.getObject()).getParentProcess();
java.util.Enumeration pinwf = wfprocess.getPrincipals(wt.project.Role.toRole("MY_ROLE_TO_TEST"));
int count = 0;
while (pinwf.hasMoreElements())
count = count+1;
pinwf.nextElement();
if count==0 no person have been slelected for this role ... so you can route your workflow differently
regards
Gregory
Thanks a lot mr.gregory...Iam getting the role for which there is no participant but how can i stop the task from going to anyone..
GregoryPERASSO
You can set the "count" as a global workflow variable.
And then after your setup participant task, put a conditionnal robot.
If count = 1, route to the next task where the partipant is needed
If count=0, route to another way with no task for this participant
Hi all,
I know it's an oldish thread, but I didn't want to start a new one on the same subject.
Does anyone have a working example of this code inside a simple workflow? No matter how I try to implement it in WC10.1 M40, it doesn't want to work.
TIA
HI Bob,
I tried to implement the solution with a littlle bit different approach.
I also have a document for it.
But i dont know how to how to upload a document.So uploaded the picture of the workflow.
It may help you.
Thanks And Regards,
Kaushik
Thanks, Kaushik - unfortunately it does help me a great deal!
The problem is that however I try to implement the code listed in this thread, whether by including it in WorkflowHelper or inside a conditional router, or inside a Complete Transition, I get the following error;
java.lang.ClassCastException: wt.workflow.engine.WfProcess cannot be cast to wt.workflow.work.WfAssignedActivity
Nested exception is: java.lang.ClassCastException: wt.workflow.engine.WfProcess cannot be cast to wt.workflow.work.WfAssignedActivity
wt.util.WTException: java.lang.ClassCastException: wt.workflow.engine.WfProcess cannot be cast to wt.workflow.work.WfAssignedActivity
at wt.workflow.expr.WfExpression97382.execute_ROUTER_EXPRESSION_(WfExpression97382.java:23)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at wt.workflow.definer.WfExpression.invokeByReflectionWithTransaction(WfExpression.java:1204)
at wt.workflow.definer.WfExpression.executeRouter(WfExpression.java:1322)
at wt.workflow.definer.WfExpression.execute(WfExpression.java:416)
at wt.workflow.engine.WfConnector.evaluateRouterExpression(WfConnector.java:586)
at wt.workflow.engine.WfConnector.fire(WfConnector.java:350)
at wt.workflow.engine.WfConnector.fireInput(WfConnector.java:314)
at wt.workflow.engine.ActivityConnectorLink.receiveEvent(ActivityConnectorLink.java:143)
at wt.workflow.engine.StandardWfEngineService.propagateEvent(StandardWfEngineService.java:861)
at wt.queue.QueueEntry.execute(QueueEntry.java:232)
at wt.queue.QueueRunnable.run(QueueRunnable.java:186)
at java.util.concurrent.ThreadPoolExecutor$Worke
What is I'm missing, or doing wrong?
(None of this helped by the fact that I'm not a programmer!!!)
Bob.
