We've been running 9.1 M020 since last September.
Overall its fine, with one major exception: the "Save As" feature for creating CAD data from existing data is broken. Calls to PTC tell us that its fixed in 9.1 M030. I can't really figure out how they could release something broken like that. It worked in the old 9.0 M040 installation we had. Of course, we knew it existed, but didn't really have a use for it. Then after we upgraded, several people came to me wanting to use it, and then we determined its broken. To be fair, it wouldn't have stopped us from upgrading at the time, because we desperately needed to update to 9.1 M020 to get to SW2009. At that time, M030 wasn't going to be released until August, and we were already too far down the upgrade path.
Oh, and the display of Attributes lists the full name, instead of the Display Name. Not a problem, just makes it look funny. Was also reported to be fixed in M030.
We're planning on finishing a few other projects here, then updating to M050 starting in April... so we can finally run SW2010 (although only on XP/Vista, even though M040 introduced Win7 support).
We have upgraded our productive system from 8.0 M040 to 9.1 M030 on November 21st 2009.
Overall it's running ok.
The best improvement is that we can configure almost all tables to display our IBAs, which was only possible in the Workspace tables in Windchill 8.
I also like the Subfolder tree, which is more Windows Explorer like.
We have some troubles with EPMDESCRIBELINKS (links between Pro/E drws and WTParts) still left over from WC 8 and our FAST-index is not running well, but all in all the upgrade was successful!
Best regards and good luck!
Johannes
We also upgraded on November 21 from 8.0 M040 to 9.1 M020. Fast is not functioning. It has taken since then to index the system and we are almost done. When the indexing was first started we could do searches, but now we can not search without getting errors and tech support is not much help.
Yes,
Just completed a minor customization:
We want to have PBO number and rev available as possible fields to display on the assignments pages (Home, Product, and Library)
EX:
In site.xconf add:
<service context="default" name="com.ptc.core.htmlcomp.tableview.ConfigurableTable"<br"/>targetFile="codebase/com/ptc/windchill/enterprise/enterprise.service.properties">
<option<br/>serviceClass="ext.baesystems.enterprise.work.BAEHomeOverviewAssignmentTableViews"
selector="netmarkets.overview.assignments.list"
requestor="java.lang.Object"
cardinality="duplicate"/>
</service>
<option<br/>serviceClass="ext.baesystems.enterprise.work.BAEProductAssignmentTableViews"
selector="netmarkets.product.assignments.list"
</service>
<option<br/>serviceClass="ext.baesystems.enterprise.work.BAELibraryAssignmentTableViews"
selector="netmarkets.library.assignments.list"
</service>
Update the following jsps:
netmarkets/jsp/work
listOverviewAssignments.jsp
listProductAssignments2.jsp
listLibraryAssignments2.jsp
like so:
[cid:image002.jpg@01CAB6FA.CB6F03D0]
Create the following classes:
ext/baesystems/enterprise/work
BAEHomeOverviewAssigmentTableViews
They look like:
public class BAEHomeOverviewAssignmentTableViews extends HomeOverviewAssignmentTableViews {
public BAEHomeOverviewAssignmentTableViews() {
super();
public List getSpecialTableColumnsAttrDefinition(Locale locale) {
List superList = super.getSpecialTableColumnsAttrDefinition(locale);
superList.add(new Attribute.TextAttribute("number", "Number", locale));
superList.add(new Attribute.TextAttribute("version", "Version", locale));
return superList;
public class BAEProductAssignmentTableViews extends ProductAssignmentTableViews {
public BAEProductAssignmentTableViews() {
super();
return superList;
public class BAELibraryAssignmentTableViews extends LibraryAssignmentTableViews {
public BAELibraryAssignmentTableViews() {
super();
return superList;
Hope that helps
John English
Here is some info from a PTC TSE as well. We followed their solution with only a minor deviation.
You can customize the listOverviewAssignments.jsp page to add the 2 custom columns like below. The OOTB NumberDataUtility and VersionDisplayDataUtility should be able to render these columns for you.
<jca:describecolumn id="number" sortable="${sortable}" isinfopagelink="false" datautilityid="NumberDataUtility" targetobject="primaryBusinessObject.object"/>
<jca:describecolumn id="version" sortable="${sortable}" need="iterationDisplayIdentifier" datautilityid="VersionDisplayDataUtility" targetobject="primaryBusinessObject.object"/>
You will also need to add the 2 columns to your Views. The OOTB Views for this Assignments table are defined in HomeOverviewAssignmentTableViews.class . you can create a custom class similar to this, modify the getSpecialTableColumnsAttrDefinition method to add the new columns.
arraylist.add(new com.ptc.core.htmlcomp.createtableview.Attribute.TextAttribute("number", "Number", locale));
arraylist.add(new com.ptc.core.htmlcomp.createtableview.Attribute.TextAttribute("version", "Version", locale));
The Views should now show up when you click on "Customize View". You might have to delete the existing views, clear Tomcat cache and restart Windchill to pick up the changes.
DELETE FROM TableViewDescriptor;
DELETE FROM ActiveViewLink;
commit;
and
To have the Assignments page use your custom class, you will need to define your own custom properties file to define the service class.
The enterprise.service.properties file has the entry defined for the OOTB Assignments table (for Home/Library/Product/Overview). You will need to create your custom property file and xconf file with a similar entry: (sample files attached)
Custom .properties file:
wt.services/svc/default/com.ptc.core.htmlcomp.tableview.ConfigurableTable/netmarkets.overview.assignments.list/java.lang.Object/0=<custom class=" with=" full=" package=" name=">/duplicate
And your custom .xconf file. The highlighted entry is the Selector for the Assignments Overview table, you define your custom class for the Selector so it picks up the custom class instead of the OOTB class.
<configuration targetfile="codebase/<path" to=" <custom=">.properties">
<service context="default" name="com.ptc.core.htmlcomp.tableview.ConfigurableTable">
<option requester="java.lang.Object" selector="netmarkets.overview.assignments.list" serviceclass="<custom" classname=">">
</service>
</configuration>
These are the OOTB Properties defined in enterprise.service.propreties and enterprise.service.xconf files for ALL the Assignments tables:
1)wt.services/svc/default/com.ptc.core.htmlcomp.tableview.ConfigurableTable/netmarkets.assignments.list/java.lang.Object/0=com.ptc.windchill.enterprise.work.assignmentslist.views.HomeAssignmentTableViews/duplicate
2)wt.services/svc/default/com.ptc.core.htmlcomp.tableview.ConfigurableTable/netmarkets.library.assignments.list/java.lang.Object/0=com.ptc.windchill.enterprise.work.assignmentslist.views.LibraryAssignmentTableViews/duplicate
3)wt.services/svc/default/com.ptc.core.htmlcomp.tableview.ConfigurableTable/netmarkets.product.assignments.list/java.lang.Object/0=com.ptc.windchill.enterprise.work.assignmentslist.views.ProductAssignmentTableViews/duplicate
1)<option serviceclass="com.ptc.windchill.enterprise.work.assignmentslist.views.ProductAssignmentTableViews"<br"/>requestor="java.lang.Object" selector="netmarkets.product.assignments.list" cardinality="duplicate"/>
2) <option serviceclass="com.ptc.windchill.enterprise.work.assignmentslist.views.LibraryAssignmentTableViews"<br"/>requestor="java.lang.Object" selector="netmarkets.library.assignments.list" cardinality="duplicate"/>
3)<option serviceclass="com.ptc.windchill.enterprise.work.assignmentslist.views.HomeAssignmentTableViews"<br"/>requestor="java.lang.Object" selector="netmarkets.assignments.list" cardinality="duplicate"/>
4)<option serviceclass="com.ptc.windchill.enterprise.work.assignmentslist.views.HomeOverviewAssignmentTableViews"<br"/>requestor="java.lang.Object" selector="netmarkets.overview.assignments.list" cardinality="duplicate"/>
Once you create your own property files, you must add it to the below property in wt.properties file using xconfmanager. To add my training.properties, I would do something like this:
wt.services.applicationcontext.WTServiceProviderFromProperties.customPropertyFiles=..........,ext/training/training.properties
Hi Tina,
just to let you know: I described our FAST problems in Mike's new thread: here
Best regards
In Reply to Tina Maccalous:
In Reply to Johannes Schramm:We also upgraded on November 21 from 8.0 M040 to 9.1 M020. Fast is not functioning. It has taken since then to index the system and we are almost done. When the indexing was first started we could do searches, but now we can not search without getting errors and tech support is not much help.
