SolidEdge CAD data management problems
KeeperOfThe7Ks
Version: Windchill 12.0
Use Case: Hi, We are using SolidEdge since 2018, going through different Windchill-SolidEdge-CADi versions and we are constantly facing problems: - CAD data marked as our of date. - CAD data saved but not marked as modified. - Drawings published with the wrong attributes displayed. These problems are occurring randomly, but they have a huge impact in our activities. I have created several tickets with PTC and Birlasoft, but they have not solved the problem. Is anyone familiar with this kind of problems? Many thanks
Description:
Problems apparently occurring randomly.
  • After the check-in some CAD data is marked out of date, performing refresh or update is not removing the mark. Synchronizing the workspace can work, but often it's asked to check-out some data.
  • Sometimes after the check-in the local modified data is replaced with the commonspace unmodified data.
  • Sometimes the drawings are published with wrong attributes (the actual drawing shows the right one, the published PDF is not).
6 REPLIES 6
Is it possible to show some screen shots of what you are seeing?
I'll reproduce the issue and then send screenshots and steps performed.
Many thanks
Kindly Share details.
I'm not able to reproduce all the problems reported above, except for the 1st one:
  • After the check-in, some CAD data is marked out of date; performing refresh or update is not removing the mark. Synchronizing the workspace can work, but often it's asked to check-out some data.
This topic is described in Article - CS223174; the main difference is that performing an update and then a refresh as suggested is not always resolving fixing the out of date.
This is an annoying problem, but it is not dangerous for us as the other ones.
Focusing on the other problems:
  • Sometimes the drawings are published with wrong attributes (the actual drawing shows the right one; the published PDF does not).
One of our engineers just had the problem.
He has revised and modified a CAD model, but after the check in the CAD file was the "previous one", like the commonspace one (or the server side WS CAD file).
SolidEdge file latest iterationSolidEdge file latest iterationContent of the iterationContent of the iterationHistory of the CAD fileHistory of the CAD file
We have a further problem with the drawing; in the local WS the number of the revisions on the drawing frame is 2 and it is right, but in the Windchill PDF it is still 1 while other changes have been properly applied.
SolidEdge drawing file latest iterationSolidEdge drawing file latest iterationCAD file contentCAD file contentDrawing historyDrawing history
