Has anyone had any luck setting up the Solidworks 'Design Library' to work with Windchill? Searching the Windchill Help Documentation doesn't seem to yield any results.
It seems like Solidworks 'Design Library' setup files need to be on a local or network folder. I would guess Windchill wouldn't like this (ghost objects, possible publishing problems, etc.).
Note: the Solidworks 'Design Library' is not the Solidworks Toolbox (which has a Windchill help page for how to configure with Windchill).
Hi @lhoogeveen ,
The SWX Design library is not yet supported by Windchill.
https://www.ptc.com/en/support/article/CS386898
Priyanka
Hi @lhoogeveen ,
Priyanka
