I import solidworks files using WWGM but the publishing/thumnail is not working.
I already did the command in windshell
xconfmanager -t C:\ptc/Windchill\codebase\wvs.properties -s "publish.cadfileextensionfilter= ASM PRT DRW IAM IPT IDW DWG SLDPRT SLDASM SLDDRW" –p
xconfmanager -t C:\ptc/Windchill/codebase/WEB-INF/conf/wvs.properties -s worker..SLDPRT=DUMMY,preconverted=true
But i have no luck
can somedody tell me wat seems to be the problem?
Thanks!
