Recently did an upgrade of PDMLink 11.1 to 12.0 on a test sever, and we wanted to re-index all of our Solr entries. Running Solr on a standalone server, and deleted the existing entries to start the re-index. All of the entries are failing. Double checked the connections and made sure the Solr admin and password match on the 2 servers. i know you now longer have to create the cores, but was wondering if I should blow them away and do a manual build. Just inquiring to see if anyone else has experienced this. Many thanks in advance!
Did you also set up the solrserver.properties file?
CS353251
Thanks for the info Mike. This was one of the first solutions I tried.
Any firewall blocks between or on the servers?
