Has anyone had success with setting up a Number Sequence (or other source of Numbers) that does not drop numbers or otherwise create gaps as the OOTB Number Sequences do? I get that for the most part, the primary function of Number is to guarantee uniqueness, but there are some use cases where gaps in the Number Sequence is a factor in usability (mostly User perception).
