Where do we specify starting of the number or prfix In autonumbering customization for Windchill ?
i.e. I want numbers to start 230010x (x being incremented every time)
Thx
Manually in the database for that particular sequence. Let me look for the command...
Found it. See this post and the corresponding article.
You could also set the 230010 as a prefix in your OIR for new parts then use a sequence table for the rest of your number.
As with any number sequence table, it may generate numbers that never get used. You also need to set the sequence increment to 1 instead of the default, I think it is 10.
Where within OIR ?
Could please you add snippet of pic ?
I also checked in prefs ....no luck
Only if the '10' at the end is not expected to increment. Depends on what behavior is desired.
OIR Method:
2300101
2300102
2300109
23001010
23001011
23001099
230010100
230010101
Set Sequence Method:
2300101
2300102
2300109
2300110
2300111
2300199
2300200
2300201
Still not clear on Where within OIR ?
