Storage conflict error
Level 1
When trying to open an assembly I keep getting an error saying there is a
storage conflict because a family table is not completely checked out into
my workspace. You can just hit OK and the assembly opens fine but my
problem is that when batch publishing to ProductView there is no ability to
hit OK so the publishing fails. I don't want to have all the instances
checked out as a rule because that is a waste of time when publishing. I
can understand why I would get this error when saving an assembly with an
incomplete family table, but not while opening.
Has anyone got a clue as to why this would be happening or how to fix it?
Small image file attached of the error window.
Mark Dolata
CenterLine (Windsor) Ltd.
(See attached file: storage_conflict.gif)
