Hi everyone,
I have a strange problem that has popped up on a remote user. The user is running Intralink 9.1 M050 and WF4 M180 at a remote site that has a fileserver. His products are mastered on this server and there is a global library that is replicated to that site daily. When he starts Pro/E, checks out some files, and attempts to open on of the objects he gets a File Download dialog (see attachment) asking if he wants to open or saveobjectname.pha. If he clicks open the Pro/E object opens but any changes made and then saved seem take place but the Workspace does not record the object as Modified. Subsequently no check in can be done as Intralink does not recognize the object modification. I completely removed his workspace (removed .wf folder) and even had him try a different computer....no luck. Has anyone seen this issue.
Bob Mills
Bob -
We may be seeing a similar issue here related to the Symantec update except that the user's machine locks up and reboots. Was your issue fixed by disabling the 'stealth mode web browsing' option?
Thanks in advance -
Chrystal Johnstone
Red Dot Corporation
