Strings are limited to 500 characters
CraigFinney
Windchill strings are limited to 500 characters.  A locked constraint.  How do you increase the string length to 750 or given another option for a larger String when defining a new attribute?
https://www.ptc.com/en/support/article/CS24652?source=search
There is a link to the customizer's guide.
Not sure if you are referring to Enumerated Types (i.e. create a new String2 type), or creating Large Objects (LOBs).
HelesicPetr
(To:CraigFinney)
Hi @CraigFinney
If you go through the guide that @avillanueva has provided, you will find a way how to increase the character limit up to 2000 chars for IBA string attributes.
Knowledge base
PetrH
