Support for Oracle Database Encryption at Rest
avillanueva
23-Emerald I
Linking back to this post which appears unresolved: Does anyone know if Windchill supports Data encryption AT REST and IN TRANSIT within ORACLE or between ORACLE and the Application Server
@ScottMorris , did you ever find an answer on this?
My DBA pinged me on this recently. I see in docs that Oracle Transparent Data Encryption (TDE) tablespace encryption is documented and supported along with JDBC over SSL. From what I am told, TDE is not supported with Oracle Standard Edition. They are asked about Table Level Column Encryption called DBMS_CRYPTO. Reply back if you have anymore information.
I did not. This quest was right before we migrated to AWS private cloud and was not required with RDS.
