Switching PDMLink OS during rehost
avillanueva
23-Emerald I
We have our installation NFS mounted. I am wondering if it was possible to rehost from a solaris OS to a Red Hat OS just by remounting following the normal rehost steps. Does Apache, Tomcat, Windchill DS or Windchill care if underlying OS is changed? Most scripts typically have the OS detect portions but I was wondering if some are built during installation that were Solaris specific, if I have to do a brand new install on RH and then swap DS LDAP and site.xconf settings.
Antonio Villanueva - Sr. Software Engineer - ISR Systems
UTC AEROSPACE SYSTEMS
100 Wooster Heights Road, Danbury, CT 06804
Tel: +1 203 797 5682
antonio.villanueva@utas.utc.com<">mailto:antonio.villanueva@utas.utc.com> www.utcaerospacesystems.com
CONFIDENTIALITY WARNING: This message may contain proprietary and/or privileged information of UTC Aerospace Systems and its affiliated companies. If you are not the intended recipient please 1) do not disclose, copy, distribute or use this message or its contents, 2) advise the sender by return e-mail, and 3) delete all copies (including all attachments) from your computer. Your cooperation is greatly appreciated.
Apache most certainly does because the binaries are architecture specific. Probably some other binaries also architecture specific. From a Solaris x86 install:
wc# pwd
/opt/ptc/Windchill/HTTPServer/bin
wc# file httpd
httpd:          ELF 32-bit LSB executable 80386 Version 1, dynamically linked, not stripped
wc# cd ../lib
wc# file *
apr.exp:        executable libapr-1.so script
aprutil.exp:    executable libaprutil-1.so script
libapr-1.a:     current ar archive, 32-bit symbol table
libapr-1.la:    commands text
libapr-1.so:    ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped, no debugging information available
libapr-1.so.0:  ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped, no debugging information available
libapr-1.so.0.4.8:      ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped, no debugging information available
libaprutil-1.a: current ar archive, 32-bit symbol table
libaprutil-1.la:        commands text
libaprutil-1.so:        ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped, no debugging information available
libaprutil-1.so.0:      ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped, no debugging information available
libaprutil-1.so.0.5.2:  ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped, no debugging information available
libexpat.a:     current ar archive, 32-bit symbol table
libexpat.la:    commands text
libexpat.so:    ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped, no debugging information available
libexpat.so.0:  ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped, no debugging information available
libexpat.so.0.5.0:      ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped, no debugging information available
pkgconfig:      directory
wc#
> *Antonio Villanueva *-- Sr. Software Engineer -- ISR Systems
> *UTC AEROSPACE SYSTEMS*
> *Tel: *+1 203 797 5682
> _antonio.villanueva@utas.utc.com <__www.utcaerospacesystems.com_">mailto:antonio.villanueva@utas.utc.com>__www.utcaerospacesystems.com_
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
We're working a similar transition from AIX to Linux (RH). We have had a bit of a challenge with Java (we were not using the PTC-provided java but instead AIX 64-bit Java) and more so with Apache. I had to hand off the project to a co-worker so I don't know the details but know where to ask.
I did ask PTC first about AIX to Linux and they reported no issue. I'm afraid this doesn't guarantee Solaris to RH but I think it's likely OK.
Seems like I should confirm with PTC. I do not intend to touch system again until 10.X so if its only a note in PSI, I could care less.
> wc# pwd
> wc# file httpd
> wc# cd ../lib
> wc# file *
> wc#
I almost forgot the most obvious is the Java runtime (if you use the PTC supplied java). Also other architecture specific binaries are located in tomcat/connectors/sjsws, solr-basis, and wvs. This is from Windchill 10.2 M010 on Solaris x86:
wc# pwd
/opt/ptc/Windchill/Windchill
wc# find . -type f -exec file {} \; | grep ELF
./tomcat/connectors/sjsws/i386/nsapi_redirector.so:     ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./tomcat/connectors/sjsws/sparcv9/nsapi_redirector.so:  ELF 64-bit MSB dynamic lib SPARCV9 Version 1, dynamically linked, not stripped, no debugging information available
./tomcat/connectors/sjsws/amd64/nsapi_redirector.so:    ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped, no debugging information available
./tomcat/connectors/sjsws/sparc/nsapi_redirector.so:    ELF 32-bit MSB dynamic lib SPARC Version 1, dynamically linked, not stripped
./wvs/sun_solaris_x64/obj/pvschange:    ELF 64-bit LSB executable AMD64 Version 1 [SSE2 SSE FXSR CMOV FPU], dynamically linked, stripped
./opt/psm/agent/downloads/5.5.0.5563/native/solaris-x86-64/libdtagentcore.so: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, stripped
./opt/psm/agent/64/libdtagent.so:       ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, stripped
./opt/psm/agent/32/libdtagent.so:       ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbtrlijni.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libicui18nbt.so.40: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libicudatabt.so.40: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped, no debugging information available
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbtrlpcore.so.7.5: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libicudatabt.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped, no debugging information available
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbtrlpc.so.7.5: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbtrlpjni.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbtunicode.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbtutils.so.7.5: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libstlport.so.1: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped, no debugging information avail able
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbtrliprofile.so.7.5: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libicuucbt.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libicudatabt.so.40.1: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped, no debugging information available
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbtrlpc.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libicui18nbt.so.40.1: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libicuucbt.so.40.1: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libicui18nbt.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbtutils.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbtrlpcore.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbteuclid.so.7.5: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbteuclid.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbtutiljni.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libicuucbt.so.40: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/lib/ia32-solaris10-cc58/libbtrliprofile.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_op_dump_html.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_jma.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/btrow42.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_bucket_loader.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_sgmlentitytransform.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_cla.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_htmltables.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_term_expander.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_stop.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_htmljoiner.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/build_kla_user_dictionary: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_ne_redact.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_word_break.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_arbl.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_lemmatizer.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_fabl.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/rlp_examples: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_gazetteer.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_kla.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_urbl.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/btchi42.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/t5sort: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_rclu.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_ne.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/rlp_sample: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/rlbl_sample: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/build_jla_user_dictionary: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_stemmer.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_op_rawdump.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/rli: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/rlp_sample_c: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_scrbd.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_tbd.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/btkor42.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/jla_user_dictionary_util: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_bl1.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_unicode_converter.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_bnp.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_mime_detector.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_apne.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/rlp: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/examine_license: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/btlat42.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_ip_bbxml.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_htmlstripper.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_rli.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_op_rexml.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_csc.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/btjpn42.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_rexml.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_regexp.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/examine_license_c: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_lbd.so: ELF 32-bit LSB dynamic lib 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/cla_user_dictionary_util: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_m1norm.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/t5build: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/ngsample: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_fragment_detector.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/build_cla_user_dictionary: ELF 32-bit LSB executable 80386 Version 1 [FPU], dynamically linked, not stripped
./solr-basis/solarisintel32/rlp/bin/ia32-solaris10-cc58/bt_lp_sentence_break.so: ELF 32-bit LSB dynamic lib 80386 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbtrlpjni.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbtrliprofile.so: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libicui18nbt.so.40.1: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbtrlpcore.so.7.5: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbtrlpc.so.7.5: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbtrlpc.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbteuclid.so.7.5: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libicudatabt.so.40.1: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped, no debugging information available
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbtrlijni.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbtutiljni.so: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libicuucbt.so.40.1: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbtutils.so.7.5: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbtrlpcore.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbtutils.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libicui18nbt.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbtunicode.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libstlport.so.1: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV FPU], dynamically linked, not stripped, no debugging inf ormation available
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libicuucbt.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbteuclid.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libicudatabt.so.40: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped, no debugging information available
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libicui18nbt.so.40: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libicuucbt.so.40: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libicudatabt.so: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped, no debugging information available
./solr-basis/solarisintel64/rlp/lib/amd64-solaris10-cc58/libbtrliprofile.so.7.5: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/btkor42.so: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_unicode_converter.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_stop.so: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/t5build: ELF 64-bit LSB executable AMD64 Version 1 [SSE2 SSE FXSR CMOV FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_sentence_break.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/jla_user_dictionary_util: ELF 64-bit LSB executable AMD64 Version 1 [SSE FXSR FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_m1norm.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/build_jla_user_dictionary: ELF 64-bit LSB executable AMD64 Version 1 [SSE2 SSE FXSR CMOV FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_fabl.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_rexml.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_op_rawdump.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/btlat42.so: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_urbl.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_tbd.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/rlp_sample_c: ELF 64-bit LSB executable AMD64 Version 1 [SSE FXSR FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_bnp.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_bl1.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_arbl.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_op_rexml.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_regexp.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_rclu.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/examine_license_c: ELF 64-bit LSB executable AMD64 Version 1 [SSE FXSR FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/btjpn42.so: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_ip_bbxml.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_lbd.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/examine_license: ELF 64-bit LSB executable AMD64 Version 1 [SSE FXSR FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_mime_detector.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_fragment_detector.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_scrbd.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/build_kla_user_dictionary: ELF 64-bit LSB executable AMD64 Version 1 [SSE2 SSE FXSR CMOV FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/cla_user_dictionary_util: ELF 64-bit LSB executable AMD64 Version 1 [SSE FXSR FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_rli.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_csc.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/rlp: ELF 64-bit LSB executable AMD64 Version 1 [SSE2 SSE FXSR CMOV FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_ne_redact.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_htmlstripper.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/rlp_examples: ELF 64-bit LSB executable AMD64 Version 1 [SSE FXSR FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_gazetteer.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_kla.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/btrow42.so: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_op_dump_html.so: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_jma.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/btchi42.so: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_sgmlentitytransform.so: ELF 64-bit LSB dynamic lib AMD64 Version 1, dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/build_cla_user_dictionary: ELF 64-bit LSB executable AMD64 Version 1 [SSE FXSR FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_cla.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_apne.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/rli: ELF 64-bit LSB executable AMD64 Version 1 [SSE2 SSE FXSR CMOV FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/t5sort: ELF 64-bit LSB executable AMD64 Version 1 [SSE FXSR CMOV FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_word_break.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/ngsample: ELF 64-bit LSB executable AMD64 Version 1 [SSE2 SSE FXSR FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_ne.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/rlp_sample: ELF 64-bit LSB executable AMD64 Version 1 [SSE FXSR FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_stemmer.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_lemmatizer.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_term_expander.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_bucket_loader.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/rlbl_sample: ELF 64-bit LSB executable AMD64 Version 1 [SSE FXSR FPU], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_htmljoiner.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [SSE2 CMOV], dynamically linked, not stripped
./solr-basis/solarisintel64/rlp/bin/amd64-solaris10-cc58/bt_lp_htmltables.so: ELF 64-bit LSB dynamic lib AMD64 Version 1 [CMOV], dynamically linked, not stripped
wc#
> Randy Jones
> 1525 E North St
> PO Box 5060
> email:-
> Phone: 785-823-3276
>    Fax: 785-667-2695
Randy Jones
1525 E North St
PO Box 5060
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
