Hello Community,
I´m looking for a way to find all the drawings, where specific symbol is placed, however when I search for the symbol itself in windchill, there is no refference in Where used nor Related objects.
Please, is there any way, to search for these drawings, where symbol is placed?
Thank you in advance for any feedback/idea.
Nothing easy to do that.
ModelCheck can report on symbols used in a drawing.
Compiling the information on all drawings would take a while and then you would need to filter the MC results for the symbol(s) of interest.
Are you by any chance indexing the drawings? It might be possible to see if it gets picked up in the index (Solr). One other possibility is to see if the symbol is visible in the drawing file as text when viewed in text editor. This might avoid a jtoolkit app inspection. Last option would be to script something with a macro then have a Creo session call up each one to inspect and report the results. It would be slow (30sec to a min per drawing) but you could let it run to get your answer. This would work if you were looking for a one time answer, not something I would want to repeat often.
