Text fields do not stretch in Jasper Report
RK_10805837
Hello all,
I am facing an issue with one of our Jasper Reports. There is a text field inside a table that has to be stretched according to the length of the text. I have given the textAdjust property as "Stretch Height" and also the Stretch Type but it doesnt work in the pdf format. In HTML, it works fine. I checked the Print Order of the jrxml as well and it is Vertical. Can somebody please give any suggestion in that?
Ramsha Kamal
Hi RK_10805837,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
